New 29s
Jun 27, 2007 20:16:41 GMT 12
Post by knownotmuch on Jun 27, 2007 20:16:41 GMT 12
Excellent thread. It is great to see the step by step progress. I for one will certainly be cheering you on when I get the privilege of seeing the finished car in action.
New 29s
Jul 1, 2007 16:06:05 GMT 12
Post by ford82 on Jul 1, 2007 16:06:05 GMT 12
dam every1 beat in to it was goin to tel you bout ur mounts 2 ive got them lik u hav got them nw hell of alot easier 4 puting a engine in out taking 1 out keep up the gd work stockcar
New 29s
Jul 1, 2007 20:13:07 GMT 12
Post by tank11 on Jul 1, 2007 20:13:07 GMT 12
When bolting two plate faces together, ensure you use bolts with sufficient shoulders or you run the risk of shearing your threads.
New 29s
Jul 1, 2007 21:57:00 GMT 12
Post by Saloon29s on Jul 1, 2007 21:57:00 GMT 12
When bolting two plate faces together, ensure you use bolts with sufficient shoulders or you run the risk of shearing your threads. Excuse my ignorance, but what is a "shoulder" on a bolt?
New 29s
Jul 1, 2007 22:04:07 GMT 12
Post by Speedway Central (David) on Jul 1, 2007 22:04:07 GMT 12
A shoulder bolt is a special kind of bolt. It has an unthreaded length which is precisely machined, both as to length and diameter."
Head/Shoulder/Thread
New 29s
Jul 1, 2007 23:02:02 GMT 12
Post by Saloon29s on Jul 1, 2007 23:02:02 GMT 12
Thanks. All my bolts are like that so should be all good. ;D
New 29s
Jul 2, 2007 17:29:41 GMT 12
Post by tank11 on Jul 2, 2007 17:29:41 GMT 12
Grade 8, 29s?
New 29s
Jul 2, 2007 18:56:48 GMT 12
Post by Saloon29s on Jul 2, 2007 18:56:48 GMT 12
The metric ones are 8.8's. Not sure what the imperial ones are.
New 29s
Jul 17, 2007 9:04:34 GMT 12
Post by bonezman on Jul 17, 2007 9:04:34 GMT 12
Hows the car coming along?
New 29s
Jul 22, 2007 1:08:52 GMT 12
Post by john44s on Jul 22, 2007 1:08:52 GMT 12
Hows the car coming along? The Cars coming along slowly as i was talking to Jarrod at the Carrera Markets (Gold Coast) today. He is really looking forward to getting the car done but everyone needs a holiday. good luck with the car Jarrod.
New 29s
Jul 26, 2007 23:54:39 GMT 12
Post by Saloon29s on Jul 26, 2007 23:54:39 GMT 12
As john44s has pointed out there hasn't been much done on the car in the last two weeks, actually nothing has been done. We left our apartment at 4am Aussie time and only just got home an hour ago. Opened the shed as soon as I got home and unfortunately no elves have come and finished the car for me. Never mind, I will get back into it soon and keep you all updated on the progress. Not to sure what to do on the car next, I should be thinking about getting a body and making a roll cage I guess, then I can mount the rear suspension.
New 29s
Jul 27, 2007 18:32:43 GMT 12
Post by ross56y on Jul 27, 2007 18:32:43 GMT 12
keep up the great work please as it great to read for us newbies in the sport ross
New 29s
Jul 29, 2007 20:15:01 GMT 12
Post by James98b on Jul 29, 2007 20:15:01 GMT 12
Anymore progress?? Its been good following this
New 29s
Jul 29, 2007 21:37:26 GMT 12
Post by Saloon29s on Jul 29, 2007 21:37:26 GMT 12
There should be some progress happening next weekend. Will update here then.
New 29s
Aug 5, 2007 20:04:44 GMT 12
Post by surf79 on Aug 5, 2007 20:04:44 GMT 12
just been looking at the archives and seen your old ministock. have you thought about running one of those bodies on your new stockcar? it looked great. where did you get it from? i wouldnt mind one.
New 29s
Aug 5, 2007 20:20:33 GMT 12
Post by Saloon29s on Aug 5, 2007 20:20:33 GMT 12
just been looking at the arcives and seen your old ministock. have you thought about running one of those bodies on your new stockcar? it looked great. where did you get it from? i wouldnt mind one. There were only three of those bodies made. One for myself, one for Jonathon Mercer and one for the guy that built the three cars, Shane Benton. One of those bodies would look cool on a Stockcar.I have no idea who made them or what happened to the mould though.
New 29s
Aug 5, 2007 22:05:11 GMT 12
Post by Saloon29s on Aug 5, 2007 22:05:11 GMT 12
We worked on the car today. Got the front torsion bars mounted and they are now fully functional. The front is sitting off the ground on its own, no blocks under the chassis!Torsion adjusters outside cooling after being welded. Torsions mounted to the car. Look, no blocks! The next job now will be to make a mount for the panhard bar to the chassis, get some front shocks and mount those to the axle and chassis then that is the front pretty much done. After that, seat, roll cage, rear suspension I guess. I will have to do some research on the Kirky, Harris and Racetech seats and decide which one is going to suit me and the car the best.
New 29s
Aug 13, 2007 11:23:18 GMT 12
Post by The Observer on Aug 13, 2007 11:23:18 GMT 12
awesome stuff mate - good to see the progress, and hope to see a few more pictures as work progresses.
cheers
New 29s
Aug 13, 2007 21:53:58 GMT 12
Post by mini38s on Aug 13, 2007 21:53:58 GMT 12
Hay, your car is coming along nicely, it looked good the other night when we saw it. ;D ;D
New 29s
Aug 13, 2007 23:53:26 GMT 12
Post by Saloon29s on Aug 13, 2007 23:53:26 GMT 12
awesome stuff mate - good to see the progress, and hope to see a few more pictures as work progresses. cheers I will definitely be posting more pictures. Hopefully there will be some visible progress to show soon. You can spend many hours researching how to do things and trying to find suitable parts such as shocks etc, but that stuff doesn't show up on the photos. Went to Auckland today to sort out a seat. Stopped at Mike Henry's on the way and ordered a body. Both those should be here in a couple of weeks so then I can work out where the seat will go and start building the cage. In the mean time, I will use the next couple of weeks to fully weld up the chassis. Might make up a couple of wheels too, with the correct offset then I can put the front bumper braces in. ;D
