Post by supersaloondude81 on Mar 5, 2011 20:31:18 GMT 12
Come on Togwood!!!
couch
Post by couch on Mar 5, 2011 20:36:27 GMT 12
Time to cut your number in half stick!!!
Post by Speedway Central (David) on Mar 5, 2011 20:37:41 GMT 12
top 3 should be
2nz 48a 5t
and 2 Matamata cars of 45m and 75m should be up thre
couch
Post by couch on Mar 5, 2011 20:40:48 GMT 12
Good to see Dougal in the final, but how are he and Michelle in the final when Michelle bet him in the repercharge??
Post by mod46c on Mar 5, 2011 20:41:33 GMT 12
mods 19a 9w 871c 1nz 24c 5gm pottinger had a big roll Any news on heat 2 for the Mods?
Post by lunchbox on Mar 5, 2011 20:42:35 GMT 12
NZ Saloons Night 2 Te Marua Speedway
NZ Saloon Car Championship Final (Heat 2)
MEETING POINTS REPORT Event R9 20 Laps Page 1 Issue 1 Scheduled Start 20:20 Start Sat Mar 05 21:20 _____________________________________________________________________________
Pos Car Driver Entrant Vehicle R4 R9 Total 1 2Z Brent McClymont Brent McClymont 20 18 38 2 5T Daryl Ainsley Daryl Ainsley 19 16 35 3 48A Philip Towgood Philip Towgood 15 19 34
2 K Macs v 1 Whitianga gem with Commercial Diff
Post by schumaaka on Mar 5, 2011 20:44:22 GMT 12
Just trying to put a pdf of the points as I have it here in Dunedin Ok I have just tried the link and it will allow you to down load a complete points sheet as I have it todate. I have highlighted the top 4 car that Toogood and cars that are within 20 points of him that could beat him on points If he gets to the front 2nz just needs to finish behind him to win. If 5 T gets behind toogood it will be a run off 2nz only needs 4th to gautantee a win or no more than 2 cars between him and 48 Attachments:
Post by Roxcyford on Mar 5, 2011 20:45:04 GMT 12
what happened to 24s mustang?
Post by Steve the Maori on Mar 5, 2011 20:46:05 GMT 12
mods 19a 9w 871c 1nz 24c 5gm pottinger had a big roll Any news on heat 2 for the Mods? From Boultons Facebook Page. Unofficial results heat 2. 1st 871c Luke Keegan 2nd 1nz John Jackson 3rd 24.
Post by sonic33 on Mar 5, 2011 20:46:37 GMT 12
Respective grid draws for the last heat?
Is it three heats only or a one race final after the three
couch
Post by couch on Mar 5, 2011 20:49:46 GMT 12
Points after three heats
Post by gisspeedway on Mar 5, 2011 20:50:13 GMT 12
Could we please have the Modified results too. Lone ranger sorry.. luck to get these
Post by Steve the Maori on Mar 5, 2011 20:51:40 GMT 12
Post by sonic33 on Mar 5, 2011 20:55:17 GMT 12
couch
Post by couch on Mar 5, 2011 20:58:09 GMT 12
You may be the "Slowest Maori in New Zealand" but you make up for it in detail. Well done that man!!!
Post by schumaaka on Mar 5, 2011 21:04:27 GMT 12
Respective grid draws for the last heat? Is it three heats only or a one race final after the three Combined points over 3 heats if you have a look at the attachment above it has the current points and the grids for the final heat at the bottom of the page cheers Shane
Post by lunchbox on Mar 5, 2011 21:06:37 GMT 12
Just trying to put a pdf of the points as I have it here in Dunedin Ok I have just tried the link and it will allow you to down load a complete points sheet as I have it todate. I have highlighted the top 4 car that Toogood and cars that are within 20 points of him that could beat him on points If he gets to the front 2nz just needs to finish behind him to win. If 5 T gets behind toogood it will be a run off 2nz only needs 4th to gautantee a win or no more than 2 cars between him and 48 Thanks for putting it up. 48 needs to use 74 and 75 between him and Stick. Will one from each club help the other?
Post by schumaaka on Mar 5, 2011 21:09:32 GMT 12
Respective grid draws for the last heat? Is it three heats only or a one race final after the three Combined points over 3 heats if you have a look at the attachment above it has the current points and the grids for the final heat at the bottom of the page cheers Shane In my earlier post! for the attachment
Post by supersaloondude81 on Mar 5, 2011 21:12:44 GMT 12
Dont let Mclymont win!!!!
Post by Steve the Maori on Mar 5, 2011 21:14:46 GMT 12
Dont let Mclymont win!!!! ?
