Post by shazt2 on Jul 25, 2014 16:47:06 GMT 12
HI Guys I need some info on which option is more reliable. I am about to purchase a transponder but cant decide to go wire in and forget or the original one. Any help would be greatly appreciated.
Post by Visacard on Jul 25, 2014 18:59:14 GMT 12
Both work fine but i would never waste my time with the older recharge every week model. Start the car and the transponder works with the new wire in model. one less job to do during the week too.
Post by peteg181p on Jul 25, 2014 19:15:49 GMT 12
Both work fine but i would never waste my time with the older recharge every week model. Start the car and the transponder works with the new wire in model. one less job to do during the week too. i love the hardwire one can never forget to charge it or forget to take it to the track
Post by shazt2 on Jul 25, 2014 19:38:25 GMT 12
Thanks guys I was leaning towards the wire in one but had heard people saying they had issues. I forget to charge the camera let alone having to worry about making sure the transponder is charged
Post by peteg181p on Jul 25, 2014 20:27:27 GMT 12
i think there were issues early on with the hardwire ones? but now have been sorted. i wired mint to the main ignition key and an earth and have had no trouble.
mine even managed to get a broken plastic mount and is still working. just be sure to follow the mounting instructions and you will have no issues
Post by SpeedwayLive on Jul 27, 2014 10:29:13 GMT 12
Knowing a little about lap scoring and if it was me ... ;-) .... I would go with the "Wired" version.
If you are in a contact class I would tend to solider the terminals and / or bolt all connections.
Mounting is the most important part, keep away from exhaust heat and make sure it has a clear and unobstructed view to the ground.
If in doubt ask you local scrutineers for the "Coat Hanger" to check the mounting. The rule book has some good instructions on mounting.
Post by shazt2 on Jul 27, 2014 17:37:30 GMT 12
its non contact going into a production saloon. Everyone I know has the battery type but I suck at remembering things letting alone to charge a battery lol
