Post by superlatemodel on Jan 23, 2015 19:19:37 GMT 12
Hi
Any news from the New Zealand Saloon car Champs in Blenheim.
Post by nakifans on Jan 24, 2015 5:17:57 GMT 12
These Points may not be correct, only as I see them from livelaps after Ht3 Cornerstone Group 17C J.Lovelady 41 8S C. Korff 40 57S R. Dreaver 39 24W G. Marshall 38 46E P. North 35 7T I . Murdoch 35
Matthews Mechanical Group 3NZ N.Ross 49 271 S . Cowling 44 54C R. Marsden 40 791 R.Flood 39 63w D. Spiers 38 78R c. Betts 36
Radiator Services Group 74M D. Corrin 44 2NZ B. McClymont 39 45M P . Cressy 39 16S T. Korff 38 472 L. Phillips 35 72T P . Schouten 33
Post by Speedway Central (David) on Jan 24, 2015 8:22:15 GMT 12
So far a NI 12 vs SI 6 split.
baypark - 5 stratford - 3 wellington - 2 christchurch - 2 cromwell - 2 auckland - 1 rotorua - 1 blenhiem - 1 inverargill - 1
Post by BarryB on Jan 24, 2015 9:27:46 GMT 12
These Points may not be correct, only as I see them from livelaps after Ht3 Cornerstone Group 17C J.Lovelady 41 8S C. Korff 40 57S R. Dreaver 39 24W G. Marshall 38 46E P. North 35 7T I . Murdoch 35 Matthews Mechanical Group 3NZ N.Ross 49 271 S . Cowling 44 54C R. Marsden 40 791 R.Flood 39 63w D. Spiers 38 78R c. Betts 36 Radiator Services Group 74M D. Corrin 44 2NZ B. McClymont 39 45M P . Cressy 39 16S T. Korff 38 472 L. Phillips 35 72T P . Schouten 33 Some of those qualifiers are incorrect. 1nz Chris Cowling is through, 46e Paddy North is not, yet. This link has the up to date into. www.easternstatesspeedway.net.nz/picton-itm-nz-saloon-champs-friday-23rd-january-2015Let's do it on the terracotta, Barry B
Post by Wildcat on Jan 24, 2015 9:33:40 GMT 12
84w won the run off with 72T car in 3rd heat See they have reversed that race ?? On live laps as well ?
Post by bradnorth on Jan 24, 2015 9:52:36 GMT 12
Run of between 84w and 72t was protested cannot tell you why as I don't know ... 72t was given the win and through to tonight, 1nz, 7t and 46e were all tied on points for 5th in there group 1nz and 7t went through from the repercharge which leaves 46e top non qualifying points scorer so should be off front of repercharge (will post grids when I have available) interesting night for sure started at 6pm racing was all finished by 10 with a couple run offs home by about 10:30 - track went slick fairly quickly, will be interesting to see what they do tonight to try hold some moisture in there, already 24 degrees here looking at a high of 32! In field entertainment from 4pm today, repercharge at 5:15 - racing kicks of at 6!
Post by Murray Guy (Grandad) on Jan 24, 2015 10:32:58 GMT 12
84w won the run off with 72T car in 3rd heat See they have reversed that race ?? On live laps as well ? likely a jump start. first attempt was aborted after 84w jumped the start. restart appeared to be the same but didnt restart. videoed it which will tell the story. on yellow these cars were near race speed before the green. Possibly a bit of contact.
Post by justafan on Jan 24, 2015 17:42:07 GMT 12
1nz and 2nz both out of the first race after crashing
Post by wayspeed on Jan 24, 2015 18:56:19 GMT 12
From SpeedwayLive 1st Heat
1st 74M , 2nd 8S , 3rd 72T , 4th 24W , 5th 57S SpeedwayLive has duplicate names/numbers shows 2NZ twice as DNF and no mention of 1NZ
Post by bikeboy on Jan 24, 2015 21:21:50 GMT 12
Paddy North on pole and Dan Corrin outside him for the winner take all feature,
Post by bikeboy on Jan 24, 2015 21:36:09 GMT 12
271M Steve Cowling is the new 1nz, then 46E Paddy North is 2NZ and 1nz Chris Cowling is the new 3nz
Post by Gordon on Jan 25, 2015 18:10:22 GMT 12
Well done Steve, family and crew. You showed in the DHL you were up to it. So again well done from Glenys and Gordon (ex Mt Maunganui). Also well done to Paddy North and Chris Cowling on 2nd and 3rd.
Post by Murray Guy (Grandad) on Jan 26, 2015 11:54:33 GMT 12
