NZSTC
Post by NZSTC on Feb 21, 2016 17:03:43 GMT 12
We offered to stream the draw "Live" after having seen many many discussions in the past on "How Rigged" previous draws have been.
We are only trying to pass on information as it is being released, as we are separate from the club we can only do so much.
Post by beachboy on Feb 22, 2016 9:45:21 GMT 12
The P will need to win this event as the trophy cabinet is looking a bit sad, I hope the draw helps them out as they need all the help they can get to get a Trophy.
Post by BarryB on Feb 22, 2016 11:39:39 GMT 12
Certainly is a joke the draw Not regarding who versing who But the time teams been given to repair cars between races It varies between 3 to 9 races So you think its ok for some teams to get 3 race gap Others 8 to 9 race gap It wouldnt be rocket science to space all the teams evenly If it's not rocket science wildcat, please post up here your evenly spaced draw. I personally believe it's not possible with the 12 team, 4 group format. Barry B
Post by mobilechicane on Feb 22, 2016 13:26:26 GMT 12
hi, what banking?? keep hearing about the banking.. dont see any banking... see a little camber in the track for rain run off but no banking, how high does this so called banking rise? does it really make any difference to stockcars?
Post by 4zfed on Feb 22, 2016 15:15:19 GMT 12
hi, what banking?? keep hearing about the banking.. dont see any banking... see a little camber in the track for rain run off but no banking, how high does this so called banking rise? does it really make any difference to stockcars? Where are you looking? Clearly you havent been to the track it definitely has banking & will certainly make teams racing quite different i would say.
Post by Wildcat on Feb 22, 2016 18:49:47 GMT 12
Temarua got good bit of banking But Gizzy looks like it might have more .Be interesting all right for teams racing
Post by BarryB on Feb 22, 2016 19:19:43 GMT 12
Did I read on here somewhere, 1.8 metres of banking from pole line to wall?
Post by Deleted on Feb 22, 2016 19:32:14 GMT 12
Someone on here put 6 foot of banking, so if that's a Buck -eighty in new money then that must be right, cause I heard it on Macgors
Post by Admin on Feb 22, 2016 19:34:51 GMT 12
hi, what banking?? keep hearing about the banking.. dont see any banking... see a little camber in the track for rain run off but no banking, how high does this so called banking rise? does it really make any difference to stockcars? This might give you some idea of the level of banking. screen shotsscreen shots
NZSTC
Post by NZSTC on Feb 22, 2016 19:38:09 GMT 12
hi, what banking?? keep hearing about the banking.. dont see any banking... see a little camber in the track for rain run off but no banking, how high does this so called banking rise? does it really make any difference to stockcars? A constant 12 degrees around the entire track. SOMETIMES is graded to have small table top close to the wall
Post by sonic33 on Feb 22, 2016 20:23:49 GMT 12
Photos dont do justice. It is the most extreme banking even though it has been reduced. I think it may lead to dive bombing in this meeting. Fastest line seems midtrack, so opens up the option of starting high as a following car, and then cutting through the apex as a suicide move.
If you walk out pit gate and walk to infield you will appreciate the banking. Go and look the day before. Not an ideal track for this meet, but there will be action.
Post by percy on Feb 22, 2016 20:55:50 GMT 12
Will be interesting to see how teams adapt to the track. Will teams who win the toss select to start on grid two rather than grid 1? The theory being rather than turning right on the start line it will be easier to turn left and utilise the banking on the straights to drive your opponent to the grass.
Post by tank11 on Feb 22, 2016 21:35:08 GMT 12
The banking in the corners is good. I'm 6" and when on the flag at turn 1, my eye line is under the concrete wall in the turn or pretty close to it.
walk out the gate after the water truck has gone around and see if you can stay up right walking straight down. Hence why the cars are told to cut across the grass at turn 4 to get back out.
Post by mobilechicane on Feb 22, 2016 22:45:40 GMT 12
any mathematicians on here? how wide is the track in the bends and at 12 degrees how much lift is that..it doesnt look like 6feet but looks can be decieving...the quick classes must love it. .....never mind just read the answer
NZSTC
Post by NZSTC on Feb 23, 2016 2:58:07 GMT 12
Post by BarryB on Feb 23, 2016 6:33:00 GMT 12
hi, what banking?? keep hearing about the banking.. dont see any banking... see a little camber in the track for rain run off but no banking, how high does this so called banking rise? does it really make any difference to stockcars? A constant 12 degrees around the entire track. SOMETIMES is graded to have small table top close to the wall Is that for like, when drivers want to stop for dinner? Barry B
Post by BarryB on Feb 23, 2016 6:34:54 GMT 12
The banking in the corners is good. I'm 6" and when on the flag at turn 1, my eye line is under the concrete wall in the turn or pretty close to it. To be fair, 6" (inches) is not a lot Barry B
Post by 4zfed on Feb 23, 2016 7:28:30 GMT 12
The banking in the corners is good. I'm 6" and when on the flag at turn 1, my eye line is under the concrete wall in the turn or pretty close to it. To be fair, 6" (inches) is not a lot Barry B He was quite proud Barry till you burst his bubble
Post by BarryB on Feb 23, 2016 8:15:41 GMT 12
To be fair, 6" (inches) is not a lot Barry B He was quite proud Barry till you burst his bubble I was talking about the banking you know................ Barry B
Post by 4zfed on Feb 23, 2016 9:13:00 GMT 12
He was quite proud Barry till you burst his bubble I was talking about the banking you know................ Barry B Of course you were.. Are we seeing you in Gissy this weekend? Dont forget your sunscreen and Mexican sombreros Friday is 31Deg & Sat 30deg
