Post by Deleted on Dec 26, 2017 15:54:01 GMT 12
The rule book says no open tube style diffs for stockcars, what does that term open tube style diff mean? please thsnks
Post by atmosports on Dec 26, 2017 17:48:19 GMT 12
Open tube diff is any diff where the oil can go done the open tube, I.e the axles run inside the diff tubes with oil around them. Rule is probably so if you break any axle/tube no oil gets onto the track
Post by Deleted on Dec 26, 2017 20:19:23 GMT 12
ummm somehow..umm...
Post by Deleted on Dec 26, 2017 21:52:54 GMT 12
Open tube diff is any diff where the oil can go done the open tube, I.e the axles run inside the diff tubes with oil around them. Rule is probably so if you break any axle/tube no oil gets onto the track Ummm... thats closed tube. named because the axles are enclosed in the tubes.... open tube is the type the saloons etc run, quickchanges etc. any diff where the axle itself is not covered, like in a independant diff setup in a commy or a winters in a superstock.
Post by bernie on Dec 28, 2017 19:44:22 GMT 12
Open tube diff is any diff where the oil can go done the open tube, I.e the axles run inside the diff tubes with oil around them. Rule is probably so if you break any axle/tube no oil gets onto the track Ummm... thats closed tube. named because the axles are enclosed in the tubes.... open tube is the type the saloons etc run, quickchanges etc. any diff where the axle itself is not covered, like in a independant diff setup in a commy or a winters in a superstock. or a jag or a RAV 4 or a 180 b MMMM, yes grass hopper, the drive shaft is indeed an open tube connected to the diff.
Post by Deleted on Dec 29, 2017 7:10:05 GMT 12
Ummm... thats closed tube. named because the axles are enclosed in the tubes.... open tube is the type the saloons etc run, quickchanges etc. any diff where the axle itself is not covered, like in a independant diff setup in a commy or a winters in a superstock. or a jag or a RAV 4 or a 180 b MMMM, yes grass hopper, the drive shaft is indeed an open tube connected to the diff. huh, why you call me grasshopper master? am I very wise? Or very ugly? LOL Always found it strange that a stockcars not allowed an open tube diff below and behind the driver, but is allowed an open albeit covered driveshaft right between the drivers legs. Just goes to show what they are interested in protecting more!
