Post by widefive on Mar 2, 2018 16:56:40 GMT 12
could some one please help with a good starting point for setting a j bar up in saloon / super saloon with the j bar been mounted to the left side of the chassis
Post by Deleted on Mar 2, 2018 18:36:37 GMT 12
start with the lowest point on the diff and the bar fairly level on the chassis end - the whole point of the j bar is to push that right rear tyre into the dirt, if it gets slick move the whole thing upwards. be careful - itt pushes the left rear down but can also lift the front left right up too! {watched it happen on 166H saloon}.
Always use small adjustments and write them all down so you can see what works and what doesnt.
Post by widefive on Mar 3, 2018 8:01:27 GMT 12
thank you for your reply and also explaining how it all works
j bar set
Aug 14, 2018 10:47:05 GMT 12
Post by imasinnr on Aug 14, 2018 10:47:05 GMT 12
Mount j bar on right side of chassis ( passenger side for left hand drive car) start at middle of pinion ,on diff , angle j bar up hill to chassis to start 15-20 degrees , keep moving up till it becomes too loose ,then move down till your happy ,lock it there and throw away the key!
