Post by joe on May 20, 2018 22:15:29 GMT 12
I need to find a SBC Wetsump for my Ltd Saloon 355 Chev engine. I brought the car as a Rolling Chassis. The previous owner didn't know what brand the sump was but needs to be the following measurements to fit in beside one of the Chassis rails. The original engine that came out of the Chassis had a sump with the following info. It needs to have a Kick out on both sides at the bottom of the sump. The Kickout on the same side as the oil filter has a Dipstick & a oil Fill hole with a Plug in it & measures roughly 45mm - 50mm out from the side of the sump & the other side roughly 55mm out from the side of the sump. I think it is possibly a Milodon, Moroso or Canton can anyone confirm from the info I have given. I do have photo's if I can work out how to load them. PM ok, cheers in advance
Post by joe on May 20, 2018 22:20:34 GMT 12
Post by Deleted on May 21, 2018 12:59:15 GMT 12
Call Nathan at Motor Preperations in Otorohanga , they just supplied and fitted one to my SB Chev
Post by joe on May 21, 2018 22:08:01 GMT 12
Cheers mate I will give him a call.
