Post by The Observer on Apr 19, 2007 16:35:07 GMT 12
Hi Guys, There used to be a great thread on this board on what you needed to do to a Holden v6 to get some reliability in the stock standard motor.However, no doubt due to size it has been deleted. Could I have a list of the definitly needed mods to make a standard Holden v6 VN (on wards) last a season in a stockcar please. You know - those things you'd do first if you started with fresh low km motor out of road car.  Thanks for your help in advance team! looking forward to the experience coming out to help a new-by into the v6 world.  p.s Hopefully a moderator will pin this so it stays at the top, and we don't get too many more posts on the board about it - I guess the caliber of info replied here will tell.
Post by tank11 on Apr 19, 2007 17:48:35 GMT 12
What are you up to Big O?   ?
Post by The Observer on Apr 19, 2007 19:27:27 GMT 12
Nuthin yet tanky. Helpin out a mate, but when the day comes it will be good to be able to make a decision using the information provided by some of the experiance on this board. Bit of a bummer that some good info dissappears, but hopefully we can get some quality info stuck up for those starting out.
Post by hdr on Apr 19, 2007 21:22:03 GMT 12
The most important thing you must do is when you take the crank out take the bearings to the parts shop & get them to match the part numbers, the vn had a couple of cranks & the bearings are different, so yuoll end up running the bearings & killing it.
Mods for the motor, just get everything ballanced & put it back togeather, buy a good set of race valves & springs( the std ones arnt up to it & will break) about $300, mine lasted 4 seasons.
Get the cam ground $160.
This will give you a fast & cheap little motor that will do a few seasons before you need start replacing the internals.
Make sure you run all the sensors,
The engine in my old car has just finished its 5th season & all it had done was the valve springs got replaced last year.
Checked the log book the other week & its done 56 meetings, so thats 2 maybe 3 seasons depending on how much travelling you do in a season.
The engine i used was a 94vr
Post by madphil on Apr 20, 2007 7:32:56 GMT 12
Must (for any engine): Put a set of ARP Rod Bolts in it. Must (for any engine): New Competition Valve Springs
Run all the sensors
Yes the VN has a manual and auto crank, I think the auto has 6 bolts for the flexplate, and manual has 8 bolts for the flywheel, so make sure you get the right bearings.
Once you have that covered you can start on any basic/easy mods. +Swap VN for VP Inlet manifold (water outlet at the front) +Change the Camshaft +VR Heads (much better rockers and I think better to have flowed +VR Exhaust Manifolds
Unless your going to be reving past 7500rpm I wouldn't worry about balancing it.
Or better yet start off with a VS ECOTEC V6, better heads, larger valves, higher std compression ;D
Post by tank11 on Apr 20, 2007 7:59:07 GMT 12
I would madPhil, just in case it does go past 7500.
No use undoing all that good work for the sake of a few $100.
Have balanced all my motors but the first, and not had any problems.
Post by hre on Apr 20, 2007 8:52:27 GMT 12
HDR if i remember your v6 was f/fast HDR do you need to run the stroker crank or was that just an option you took?? ;D ;D
Post by The Observer on Apr 20, 2007 11:50:07 GMT 12
Thanks for the tips guys.
I'm assuming when your talking about making sure the sensors are wired up that your still using the standard loom?
And I recall that you had your chip programmed by the Holden dealer to make it run smoother HDR, rather than purchase the expensive chip....is that right?
cheers for the advice.
Post by hdr on Apr 21, 2007 10:08:15 GMT 12
HDR if i remember your v6 was f/fast HDR do you need to run the stroker crank or was that just an option you took?? ;D ;D  didnt no you put that in there, & paid for it to. ;D oh well at least its legal to run it.
Post by hdr on Apr 21, 2007 10:15:04 GMT 12
Thanks for the tips guys. I'm assuming when your talking about making sure the sensors are wired up that your still using the standard loom? And I recall that you had your chip programmed by the Holden dealer to make it run smoother HDR, rather than purchase the expensive chip....is that right? cheers for the advice. yup run the standard loom. Correct a dealer can change the computer, but that was only to change the timing & the rev limiter & to tell it that some parts are removed( ie the injection, throttle body, auto trans etc) & to stop it going into limp mode. These chips that they are changing dont make any difference as the electronic fuel injection, & throttle bodies are gone, Ring Bathurst performance who sell the chips & they will tell you what they do & are a waste of time for us.
Post by The Observer on Apr 23, 2007 12:26:29 GMT 12
Hi Guys,
This is great stuff. Just another couple of quick questions;
Are the anncilaries interchangable between the VN, VP, and VR motors? ie Starter motor, alternator, loom computer etc
I understand the Ecotec motor may be differenct again due to its different external mass.
cheers
Post by hdr on Apr 24, 2007 13:16:24 GMT 12
Yes most of them are from the vn to the vr. some early vn motors had different inlet manifolds. use a vp computer they are a bit smaller, the vr, vs computers are longer & take up more space.
Post by barnboy69c on Apr 24, 2007 17:53:45 GMT 12
i have a v6 motor it is auto can i get a bolt on flywheel that will fit it
Post by The Observer on Apr 26, 2007 15:05:25 GMT 12
i have a v6 motor it is auto can i get a bolt on flywheel that will fit it Thats a good question. I recall there are a couple of different people who make these - and a fine job they do by all accounts, that you pay a premium for. However there has been mentioned in the past there are other ways to get a flywheel on - can anyone else help?
Post by Mav, back bein a pit biarch on Apr 26, 2007 15:07:33 GMT 12
i have a v6 motor it is auto can i get a bolt on flywheel that will fit it Wasn't Steve Hampton Engineering mentioned at one stage?
Post by farmfrog on Apr 27, 2007 16:58:22 GMT 12
does any one have a phone number for him
Post by brendonw on Apr 27, 2007 23:48:14 GMT 12
HRP Performance Phone:(07)849 7241 email: hampton.eng@xtra.co.nz
Post by hdr on Apr 29, 2007 10:48:54 GMT 12
Alan Haigh 1nz modified made mine. 09 4433609.
Post by kahnage on May 29, 2007 0:17:07 GMT 12
zitadel
To make it easier for us can you please split your above post into paragraphs?
Post by The Observer on May 29, 2007 9:18:04 GMT 12
Awesome Job zitadel, Stockcar 55A !
Great to get your perspective, and keep the updates coming.
And importantly good luck for the rest of the offseason - it sounds like things are moving forward allright!
