Post by spuddy on Jan 17, 2021 21:50:29 GMT 12
Yeah you’re right there, correct that he didn’t officially protest, but did seem to go out of his way to yarn to an offical as well
Post by Deleted on Jan 17, 2021 23:43:16 GMT 12
Yeah you’re right there, correct that he didn’t officially protest, but did seem to go out of his way to yarn to an offical as well As is his right. Even if he did protest, he is not in the wrong here. The car(s) that failed to turn up at the weighbridge is/are. I know I'd be pretty p!ssed if I had a fair bit of coin on a horse that was beaten by another horse whos jock then did other stuff before weighing in, wouldn't you? For Mitch to be getting abuse is not on in any way, shape or form
Post by screaminV8 on Jan 18, 2021 6:15:19 GMT 12
Unfortunately Mitch had the same BS last year, to do with the runoff. The other competitor was pinged and people ASSUMED it was because of a protest - which it wasn’t.
1NZ clearly made a mistake which the other competitors immediately noticed, so nothing wrong with ASKING an official if that meant 1NZ was excluded from the results, as would obviously have a big impact on heat 3 tactics!
Post by spuddy on Jan 18, 2021 10:26:53 GMT 12
I think looking at the 2 NZ champs meetings, it is clear that there needs to be a sit down at the end of the season and procedures put in place that is blanket across all tracks and helps out the drivers a bit, don’t need to babysit them but should be trying to help them wherever possible, especially if the fixes seem so relatively simple. We have seen 1 pro active club by all accounts with the Superstocks and one that wasn’t with the stockcars from what I can gather. 1 example is a drover or at briefing so he was tracked down, whereas at the other track there was nothing like that and he ended up being excluded. Same with the whiteboard solution for the weighbridge
I’d also be looking at rewriting the penalties, they seem far, far too excessive and extreme for me. Using the example of the weekend again, after all the money and hours spent getting the car ready, travelling to the champs, the hardest task of all in actually qualifying for the finals being completed, that for simply not hearing a pit radio call and making a briefing, he is excluded from the entire meeting, that is way over the top
