Post by Saloon29s on Jan 15, 2007 1:43:07 GMT 12
Can anyone help with this? Need to know what the modification that needs to be made to the xf dizzy that you use on the 3.9 - au falcon engines is. Also, who does it? or can you do it yourself?
Cheers
Post by worldno1 on Jan 15, 2007 9:43:53 GMT 12
have a go yourself mate!
Post by craige on Jan 15, 2007 9:59:11 GMT 12
from what i understand speedy u flip the gear cog on the bottom of the dizzy shaft and this makes it lower in the block and then picks up on the au gear drive
Post by MSTA57 on Jan 15, 2007 17:39:16 GMT 12
yep thats how ma father done it,that was for a 96' 4.0L falcon motor, simple 2 do
Post by xneilx on Jan 15, 2007 20:52:12 GMT 12
yep same as the above, knock out the tension pin and flip the gearwheel over, drill another hole for the tension pin as when you flip the gear over the hole will be where the gears are, make sure the new hole is in line with the old hole (drill press is best), also set it up so you have a couple of mil end play (not hard up against the bottom of the dizzy), then whack it in the engine, positive to positive (on the coil), negative to negative
Post by Saloon29s on Jan 15, 2007 21:50:24 GMT 12
Sounds easy as. ;D
Post by raro on Jan 15, 2007 22:13:01 GMT 12
Jarrod, check your pm. See you on the 20th.
