Post by 4stree on Feb 18, 2007 20:37:30 GMT 12
can anyone out there advise who is the expert on working 3.9 rover heads, the ones i have are late 90,s [discovery] fuel injected, any help would be much appreciated, cheers
Post by Deleted on Feb 19, 2007 7:24:45 GMT 12
rex danby in thames is worth a phone call 078688284 , does a primo job and good to deal with
Post by 4stree on Feb 19, 2007 17:05:48 GMT 12
cheers steiny, how much $$$$$ can you get into working these
Post by porry41 on Feb 20, 2007 7:31:16 GMT 12
g/day charlie just be carefull with those 3,9 heads they develope hot spots try for a set of 4.6 heads flowed totaly different from the factory bigger ports & intake bolt straight on 10.1 all injected as they dont make a carburated motor any more these heads are the same as the latest 5.2 on the other hand you can work a set of sdi 3.5 heads & are better than the 3.9 bolt straight on just leave out the bottom row of studs . hic or better still can sell you a stroker motor ;D
Post by 4stree on Feb 20, 2007 8:30:14 GMT 12
cheers porry, where can i find a set of 4.6 heads and what would they set me back ,thanks for the info, how much more would i get out of it compared to the std 3.9 heads,
Post by porry41 on Feb 20, 2007 20:04:39 GMT 12
there were some on trademe a while ago think start bid was 800 .about 30hp bolt on .hic ;D
Post by tank11 on Feb 20, 2007 20:18:38 GMT 12
On a stock or saloon Porry. Remembering we run a restricter. Not saying, just asking.
Post by 4stree on Feb 20, 2007 20:30:52 GMT 12
i need them for a stockcar
Post by tank11 on Feb 20, 2007 21:32:21 GMT 12
I realise that 4stree, that is why I was asking MrP.
I would be quite keen for that sought of HP.
Should still get a bit even with a restricter on.
Post by porry41 on Feb 20, 2007 22:17:43 GMT 12
these are road car specs my motor was built in the uk as per targa car specs going by dyno sheets 330hp but ive changed the cam to speedway specs & had to lower the comp was 14.1 ! meth materail that you cant run in a saloon would like to try it with injection hat on but can u run injection on a ltd ? another subject i suppose .i dont no about restrictor i wouldnt like to run one tank im thinking off pulling that motor out of the car thats for sale & putting the 3.9 back in it or selling the car as a roller & selling the 3.9 seperatly .but not giving that motor away for 15k so far 1 diff head 1 clutch 1 r/r tyre dusted off ;D
Post by tank11 on Feb 21, 2007 12:16:51 GMT 12
Cheers Porry.
Post by 4stree on Feb 25, 2007 20:13:39 GMT 12
hi, does anyone have a set of sdi 3.9 heads [worked or standard] to sell , cheers
Post by porry41 on Feb 25, 2007 20:50:47 GMT 12
can do std 3.9
Post by 4stree on Feb 25, 2007 21:25:42 GMT 12
cheers porry, can you give me your ph number,
Post by porry41 on Feb 26, 2007 19:55:25 GMT 12
021 2945851 or yard 07 8460293
