Post by pinball on Oct 12, 2006 17:19:15 GMT 12
I see some people are using those Yokohama "rally" type tyres which as per the rules would be illegal but people are getting away with it.
Does it really depend on perception of the groove pattern as to what would be "legal" or not?
I would like to use Dunlop rally tyres which tread is less than 10mm width but these would be deemed as racing tyres and therefore illegal.
Your thoughts or experiences please.
Post by Roaddog on Oct 12, 2006 20:47:51 GMT 12
If the tread is no more than 10mm deep x 10mm wide and the tyre has a dot rating then they are ok to use
Post by nzf2stocks. on Oct 25, 2006 20:48:18 GMT 12
Rally tyres are DOT rated as they have to be used on the road touring stages between the competition stages. A lot of the different patterns comply with stock car rules, the only thing that you need to be careful about is the duro rating as top end rally tyres are designed to wear out in 40-50k's.
Then again, when was the last time that you have seen SNZ duro rate a tyre?
Post by squeaky8g on Oct 25, 2006 21:11:17 GMT 12
Also if it has "for competition use only" on it ;it is definitely illegal and cannot be used
Post by Roaddog on Oct 25, 2006 22:59:57 GMT 12
I think you will find that they will say recomended for competition use only on most, we had a car turn up at WP with dot rated Hoozers on a stockcar witch was protested and the drivers were told that because they were dot rated they were allowed
Post by mrelshauno on Oct 26, 2006 6:22:36 GMT 12
I thought duro ratings only applied to superstocks. Not stockcars because they use road tyres.
Post by Roaddog on Oct 26, 2006 14:58:29 GMT 12
that is correct as far as I know
Post by porry41 on Oct 27, 2006 20:01:04 GMT 12
kevy the free is looking for some 900x20 tyres for the rear u no kevy he all ways runs big rear wheels .mawahahaaaa .hic ;D ;D
Post by Roger Ex 35A on Oct 27, 2006 20:35:52 GMT 12
Porry what does the above mean or have I missed something
Post by tank11 on Oct 27, 2006 23:10:22 GMT 12
Just pray he has shaved first. ;D ;D
Post by porry41 on Oct 28, 2006 7:15:51 GMT 12
a longer verson of lol . or lmao / haf/ tb /jb . etc ;D burp darn battery water
Post by Roger Ex 35A on Oct 28, 2006 10:51:59 GMT 12
a longer verson of lol . or lmao / haf/ tb /jb . etc ;D burp darn battery water Think you better stay off that busterbell tea & go back to burp_bon
Post by nzf2stocks. on Oct 29, 2006 11:35:43 GMT 12
I think you'll find that stockcar (std) tyres have to duro at 120 or more, to stop the DOT rated pure race tyres being used. IE Hoosier autocrossers, bridgestone RE86R, Yoko A008r etc
Post by mrelshauno on Oct 30, 2006 7:34:23 GMT 12
Just checked my rule book (yellow one) and in the stockcar rules there is NO mention of Duro ratings. Earlier in the Superstock rules it says when using standard road tyres, front or rear, they must duro 55 or higher.
Post by nzf2stocks. on Nov 5, 2006 12:10:20 GMT 12
Cool, that means that you can run any DOT approved road tyre as long as it meets the tread pattern rule!!!
Post by busterbell on Nov 5, 2006 12:40:16 GMT 12
Just checked my rule book (yellow one) and in the stockcar rules there is NO mention of Duro ratings. Earlier in the Superstock rules it says when using standard road tyres, front or rear, they must duro 55 or higher. rule t12-2-1 a states "all rules are to be read in conjuction with the super stock specifications". so all superstock rules apply to stockcars unless the stockcar rules say otherwise.
