Post by mcampbell on Aug 27, 2014 12:12:10 GMT 12
hi ill ask this part of the forum maybe didn't get an answer in the tec section because I mentioned it was for a ministock but anyway, how are the quick release hubs fitted to the steering shaft? welded? any pictures would be helpful thanks Mike
Post by tripod1 on Aug 27, 2014 19:37:31 GMT 12
Yep. Just weld the centre piece flush with the end of the shaft.
Post by mcampbell on Aug 27, 2014 20:35:02 GMT 12
Thanks for that might have to sleeve the shaft a bit too, quick release a tad larger diameter
muff 21w
HEYBURN built T MACS
Post by muff 21w on Aug 27, 2014 23:50:49 GMT 12
make sure you leave the spline hub a few mills up for the steering shaft end. So that you dont have to grind the weld flat if your steering wheel has a solid centre. Ron Tye's broke off at the teams for this reason!
Post by mcampbell on Aug 28, 2014 8:32:04 GMT 12
make sure you leave the spline hub a few mills up for the steering shaft end. So that you dont have to grind the weld flat if your steering wheel has a solid centre. Ron Tye's broke off at the teams for this reason! thanks good tip. would have thought you would weld the bottom as well maybe different set up. thanks again
muff 21w
Post by muff 21w on Aug 28, 2014 13:10:50 GMT 12
Yes I would...
