Post by youngone on Jan 14, 2015 16:31:32 GMT 12
So why does Blondie ( edit - a non V8) have to carry more weight for every cubic inch? because its supercharged. rule T11-1-2 (c) Maximum engine capacity 434 cu in. In the case of supercharging or turbocharging of any engine, the nominal engine cubic capacity will be multiplied by 1.7. The car will be treated in all respects as if its cylinder capacity thus increased were its real capacity. This shall particularly be the case for calculating vehicle minimum weights and maximum engine size.this means his car ich would be minimum of 802kgs if it were naturally aspirated has instead got a minimum weight limit of 921. the supercharger multiplies his engines cubic size to 229ci instead of 135ci. Thank you that makes sense
Post by woodart on Jan 14, 2015 16:40:37 GMT 12
[quote source="/ speedway tracks?? [/p] We just need to get a good looking body to sit on Blondie's car!!
[/quote].... Im not sure if halle berry is available!!
Post by brendanlucas on Jan 14, 2015 17:14:12 GMT 12
Brendon they aint going to get beaten by a port a loo for sure /Not going to happen m8 You're obviously privy to information that I dont have, I think Blondie is a promoters dream, & for some, a competitors nightmare. I hope he does get to run (I don't mean run as in 'the runs), certainly adds a big dose of interest to the class. Cheers, BL
Post by fordracer on Jan 14, 2015 17:56:57 GMT 12
Good Luck Blondie hope you get that 1NZ . You deserve it an shut all those whingers up. Go Hard use the Bumper ha. Grant Mytton
Post by 888hsv on Jan 14, 2015 18:41:47 GMT 12
because its supercharged. rule T11-1-2 (c) Maximum engine capacity 434 cu in. In the case of supercharging or turbocharging of any engine, the nominal engine cubic capacity will be multiplied by 1.7. The car will be treated in all respects as if its cylinder capacity thus increased were its real capacity. This shall particularly be the case for calculating vehicle minimum weights and maximum engine size.this means his car ich would be minimum of 802kgs if it were naturally aspirated has instead got a minimum weight limit of 921. the supercharger multiplies his engines cubic size to 229ci instead of 135ci. Thank you that makes sense Hopefully 1 of the Rotary engine builders may get wift of this thread and build him a triple rotor 20B with out the super charger as they can produce 800hp with the right porting and they sound mean as!!!
Post by dontpanic on Jan 14, 2015 19:01:04 GMT 12
I wouldn't rule out blondie's chances, from what ive seen at Huntly and on Utube it turns fast and seems to run alternative lines and gets through impossible gaps that any traditional saloon/super saloons cannot (too much weight in all the wrong places)
He will not be blocked in or held up by slow traffic that's for sure
He who passes the most cars wins
hard one to call because it hasn't run at the level yet but I wouldn't rule it out
Cheers Brendon
Post by chris13w on Jan 14, 2015 19:01:28 GMT 12
Brendon they aint going to get beaten by a port a loo for sure /Not going to happen m8 You're obviously privy to information that I dont have, I think Blondie is a promoters dream, & for some, a competitors nightmare. I hope he does get to run (I don't mean run as in 'the runs), certainly adds a big dose of interest to the class. Cheers, BL Just announcing that we have now erected a marquee over the scrutineering pad and ARE pre-selling tickets - auction on Trade Me as usual
Post by brendanlucas on Jan 14, 2015 19:04:37 GMT 12
You're obviously privy to information that I dont have, I think Blondie is a promoters dream, & for some, a competitors nightmare. I hope he does get to run (I don't mean run as in 'the runs), certainly adds a big dose of interest to the class. Cheers, BL Just announcing that we have now erected a marquee over the scrutineering pad and ARE pre-selling tickets - auction on Trade Me as usual How about streaming it as well....., more drama then anything on the tele
Post by jimmyj on Jan 14, 2015 19:15:25 GMT 12
Also be another thing might well be to noisy,
Post by 888hsv on Jan 14, 2015 19:39:56 GMT 12
Also be another thing might well be to noisy, After Huntly infringement notice Blondie has put another muffler in the exhaust system and when it ran at Stratford it was a lot quieter
Post by blondie77 on Jan 14, 2015 19:56:38 GMT 12
The reason for the weight tables giving a huge advantage to a big V8 and an incredible & unfair dis-advantage to small motors was because I could beat any big $$ car with my SD1 Rover with basically a stock standard P76 of 272 cubes. At that time I had brought in from Oz a Leyland 5.0 litre Formula 5000 motor that had the big $$ boys (girls?) s**t scared so the convinced their lackeys to change the rules a put an extra 100kg on it. They then ran a straight line through a graph with what their V8's weighed & my 100kg penalty weight & created the current Saloon car weight tables. The "unintentional" side effect was to completely disadvantage any 4 & 6 cyl motors as well as rotaries. That is why we have basically the same racecar for everybody. Depends on your point of view whether this is good or bad. Its wonderful for anybody selling expensive USA bits but not so good if you, like me, would prefer to see cars like we drive to work racing round the track.
Post by midway on Jan 14, 2015 20:01:35 GMT 12
Thank you that makes sense Hopefully 1 of the Rotary engine builders may get wift of this thread and build him a triple rotor 20B with out the super charger as they can produce 800hp with the right porting and they sound mean as!!! 99a supersaloon in auckland runs a super charger and has done for a number of years ,mr Andrews is a quiet bloke and enjoys his racing ,not being in the top order many dont take much interest in his car ,but the engineering side of it is well made and clever .
Post by jimmyj on Jan 14, 2015 20:09:17 GMT 12
98 a Midway not 99a Time for another beer m8
Post by quin10 on Jan 14, 2015 20:22:24 GMT 12
Also be another thing might well be to noisy, Ive seen it on track. Not noisey at all. Much quieter than ltd saloons.
Post by midway on Jan 15, 2015 5:06:45 GMT 12
the car should change its name to the white House ,it has more contraversy than when Clinton ran office
Post by spdwayorthehway on Jan 15, 2015 10:08:14 GMT 12
This reminds me of some time ago in Wellington, a mini running with the supers.
Post by tank11 on Jan 15, 2015 12:05:19 GMT 12
This reminds me of some time ago in Wellington, a mini running with the supers. Had some wicked head work.
Post by jimmyj on Jan 15, 2015 17:23:07 GMT 12
Blondie// Why would you have your car greens sheeted 3 times /Every one else only has it done once .If there is something wrong with it they put it in the log book then you get it fixed to the scrutineer's satisfaction What is the problem with yours has it not got a big enough waste pipe ??
Post by brendanlucas on Jan 15, 2015 17:43:33 GMT 12
Blondie// Why would you have your car greens sheeted 3 times /Every one else only has it done once .If there is something wrong with it they put it in the log book then you get it fixed to the scrutineer's satisfaction What is the problem with yours has it not got a big enough waste pipe ?? Hey Jimmy, did Blondie push you off you're bike at school? I get the feeling you just don't like him...
Post by jimmyj on Jan 15, 2015 17:48:14 GMT 12
Na ,not at all just a huge big fuss over a car that seems to be non compliant /Why bother
Should have just bought his old car back /
