Post by Deleted on May 20, 2018 10:19:45 GMT 12
What are the pros and cons of running E85 fuel in a superstock. Will it run through a normal Holley 650 double pumper . Cheers
Post by 00crewchief00 on Jun 2, 2018 22:51:07 GMT 12
needs the proper e85 metering block car will run cooler but will also use more fuel when parked up after racing back in garage need to run fuel lines dry to save the seals from being eaten.
Post by Deleted on Jun 4, 2018 13:24:56 GMT 12
Cheers for that. Is it true that e85 increases performance/ horsepower more so than avgas.
Post by 00crewchief00 on Jun 4, 2018 17:44:43 GMT 12
yes bigger bang at lower temp
Post by 00crewchief00 on Jun 4, 2018 17:45:22 GMT 12
holley make a proper E85 carb btw
