Post by 00crewchief00 on Feb 27, 2020 19:11:23 GMT 12
skimming thru 2019 edition rule book and found this...
T12-2-41 CARBURETTOR
(a) One down-draft carburettor only, with a maximum of four barrels.
(b) Two throttle return springs must be fitted to the carburettor shaft linkages.
(c) Fuel injection, supercharging and turbocharging are prohibited.
(d) Plastic fuel pump, fuel line fittings and pump bases are not permitted.
Post by tank11 on Feb 28, 2020 12:58:32 GMT 12
Run a 4 barrel for economy, not performance. More air flow through a 2 barrel.
Post by 00crewchief00 on Feb 28, 2020 14:04:44 GMT 12
Run a 4 barrel for economy, not performance. More air flow through a 2 barrel. Especially then through a restrictor plate
Post by tank11 on Feb 28, 2020 16:42:30 GMT 12
Run a 4 barrel for economy, not performance. More air flow through a 2 barrel. Especially then through a restrictor plate Might be better with a 4 barrel then?
