Post by culls79 on Feb 25, 2022 23:13:00 GMT 12
Hey team
Looking for guidance or link on what is used to join/ adapter to connect 3.8 holden/ buick to aussie 3 speed
Thank you in advance
Post by mrdamage on Mar 3, 2022 16:04:48 GMT 12
You need to purchase a specific Bellhousing to suit -
Ironforce, Mark Walford & Hampton can often have stock of them. - Depending on your application as to the depth - most of them have the bellhousings off the shelf to suit stockcars - which normally run Steel Plate firewalls approx 13mm thick you will need to account for if you aren't fitting the engine/box into a stockcar..
Chris Hall In Chch makes nice billet flywheels to suit (Manual Cranks are 6 bolt, Auto Cranks are 8 bolt) Most people use One Tonner Clutch, flywheels are blanks and he can drill them to suit whatever pressureplate you plan on using.
Post by culls79 on Mar 10, 2022 3:30:44 GMT 12
Awesome thank you 😊
