Post by Dirt_Fan on Jan 18, 2009 20:36:39 GMT 12
can someone please explain to me the difference between the chassis.all this talk of tri rails gordge flat and concord getting me confused
Post by jordy77w on Jan 18, 2009 22:01:24 GMT 12
Its hard to explane the differences without seeing photos but if you can see some photos theses cars are the type of chassis;
7p Shane Penn: Tri rail 8p Scotty Mires: tank 591p Wayne Hemi: Space frame 321w Hilton Parker: flat chassie (i think)
But there are different chassie builders out there like Rees, Gordge, Kuriger, Vasey, Gill, Podjerski etc
So a rees Space frame will be a different style and shape to most other chassis builders space frames if you know what I mean?
Post by extra on Jan 19, 2009 7:44:04 GMT 12
penn tri rail gordge not sure who built this
Post by TheFanVan.co.nz on Jan 19, 2009 8:33:34 GMT 12
not sure who built this A slightly older gordge design Anyway a tri rail has three main chassis rails The gordge kruiger type designs have two chassis rails although thats where the similarities end between the two. (example of a two chassis rail car - 829s under construction **note chassis is upside down**) Within the two chassis rail concept there are a so many different design theories . The Gill chassis for example (as I understand it) is a modified version of the gordge design however it is a effectively a different design and not just a copy under another name. A flat chassis has a main single chassis rail (photo of a HB flagracers car) Effectively there are hundreds of different designs each design has merits/drawbacks but on a really basic level these three general design concepts are shown above. I was going to add a tank chassis concept also, but alas I dont have a chassis pic of one Hope this helps - probably raises more questions than provides answers
Post by 1 pie on Jan 19, 2009 15:00:19 GMT 12
492c is the xGeoff James car (last one he drove) that had the big crash in auckland at the nz superstock title and its a Gordge
Post by Dirt_Fan on Jan 19, 2009 16:44:00 GMT 12
so basically a flat chassis is a single structural rail. a kruiger gordge type have 2 structural rails and the tri rail as it suggest has 3 main structural rails.
that my interpretation from what youve said, hopefully ive got it right.
so would i be correct in saying that from the flat through to the tri rail strength and rigidity increase?
Post by Dirt_Fan on Jan 19, 2009 16:45:04 GMT 12
to throw another into the mix whats the difference with a space frame. sorry for all the questions just never hurts to know a bit
Post by jordy77w on Jan 19, 2009 18:27:59 GMT 12
to throw another into the mix whats the difference with a space frame. sorry for all the questions just never hurts to know a bit well a space frame has 2 main chassis rails and the outriggers (the bits that come from the chassis rails to hold the siderail on) have some attach to the top chassis rail and some to the bottom, so in the case of the flat chassis the outriggers lye flat from the side rail to the main chassis rail (hence why its called a flat chassis) and i assume the space frame is called a space frame because theres a space between the out riggers? BUT then a tri-rail has the same outriggers as a spacefram and also has some that are flat like the flat chassis so im not sure how you would want to class that?
Post by Dirt_Fan on Jan 19, 2009 20:09:43 GMT 12
can really go in depth cant it. well if anyone else wants to add to this feel free as im sure there a different interpretations
Post by mal on Jan 25, 2009 11:38:48 GMT 12
you could say a tri rail is a combination of a flatty and a spaceframe
Post by wangatoa on Jan 25, 2009 14:40:53 GMT 12
I can only go from what Ive seen, but Id say a Tri-Rails pretty rigid and strong as Ive never seen a bent one. Probably the same goes for a flat chassis id say? I also read on here a while back that Tanks absorb a lot of impact when they get hit and therefore the drivers dont feel it as much?
Post by tank11 on Jan 25, 2009 15:44:34 GMT 12
But they hear it................ ;D
