Post by Cheque Book on Feb 5, 2009 15:21:05 GMT 12
Dear Stockcar/Superstock Competitor,
NOTIFICATION OF NEW VALVE LIFT CHECKING METHOD
From 21 February 2009 the Directors of Speedway New Zealand have approved a new tool to check maximum valve lift in the Stockcar and Superstock classes. All competitors are being notified of this change, because there is a possibility that some vehicles may be unknowingly outside of the regulations. The relevant rules are as follows:-
Superstocks: Rule T12-1-21
Maximum inlet and exhaust valve lift 0.500in measured at valve
Stockcars: Rule T12-2-2(l)
Maximum Inlet and Exhaust valve lift: 0.500".
Attached for your information is an outline of the new procedure, and the penalties that apply for non-compliance with the engine rules. We urge you to read this documentation and ensure your vehicle complies with the regulations.
Please do not hesitate to contact the SNZ Office if you require any additional information or clarification regarding the above matter, and we wish you all the best for the remainder of the season.
Kind regards,
Tim Savell
Chief Executive Officer - Speedway New Zealand Inc
P O Box 38, New Plymouth 4340
Phone: 06 758 6725 or 0275 764 648
TECHNICAL NOTIFICATION
Stockcars & Superstocks - New Valve Lift Checking Method
Effective 21 February 2009
The maximum inlet and exhaust valve lift permitted in the
Stockcar/Superstock classes is 0.500in. With engines using hydraulic
lifters, it has traditionally been difficult to measure the valve lift with
the current tools available to SNZ officials.
From 21 February 2009 the Directors have approved for use a new
digital tool as pictured. The new measuring method will measure the
valve lift with the engine turning either powered by the starter motor
or with the engine running under its own power.
The valve lift measurement will be taken by measuring the travel of
the valve spring retainer. However the traditional dial indicator will be
replaced with a modern digital calliper. At a measurement of 0.001
inches it is accepted in engineering that a digital calliper is as accurate
as a dial indictor.
This method will require a small blade to be inserted between the
valve spring and the valve spring retainer. The digital calliper is
mounted to the cylinder head. The Calliper has a leg extension
mounted that will extend under the small blade. As the engine is
rotated the blade will draw the calliper open until the maximum valve
lift is reached.
The method will require that the engine be run from cold for a few minutes to assure that all components
are moving freely. The rocker cover is removed and the equipment mounted. The engine is slowly rotated
on the starter to assure that the valve to be measured is in the closed position. The digital calliper readout is
set at zero at this point. The starter motor is then engaged to rotate the engine until oil pressure loads the
lifter. The amount of valve lift is read off the screen as the valve lift increases. Engine operating temp is not
necessary or required to conduct this compliance test.
Should the engine be suspected of using non-compliant lifters the driver of the car in question will be
required to remove the lifters from the engine. The technical steward will cross-examine against some
known compliant OEM lifters.
Drivers are reminded that it is their responsibility to dismantle or provide a crew member to dismantle the
engine to the state required by the Technical Steward. Engines will not be dismantled in an open
atmosphere situation unless agreed by the driver, the location of the test will be determined by the
Technical Steward, taking the availability of a suitable shed into consideration.
SUMMARY
The new tool will be approved for use from 21 February 2009, and that the penalties for using an illegal
engine are clearly outlined in the regulations. There are competitors who may be flaunting the maximum
valve lift rule, either willingly or unwillingly, so it is also appropriate to remind all competitors about the
following pertinent rules:-
G11-3-3 Technical Exclusions: Any driver found to be using an illegal engine will be excluded from the
meeting and for a further 22 days (starting from the day/night in question) by the Steward, and the driver
will be placed on report to the Directors.
T1-5 Inspection by Request: Any driver or car owner may request for their own vehicle and equipment
to have technical tests done, i.e. motor, weight, fuel, etc. These tests may take place away from a meeting
and carry no penalties to the driver or owner. A fee may be charged for travel by the Technical Steward.
Kind regards,
Tim Savell
as a dial indictor.
lift is reached.
SUMMARY
