Post by sketchy on Aug 31, 2009 0:25:43 GMT 12
was just an analogy about the RSJ. your wall section measurement(vertical or horizontal) gives it the strength in that particular axis(the more height=the less likely it will bend in that direction) as each box section has 2 of those faces and your then using 4 of that section when you laminate 2 together... there is a reason they make RSJ's deeper in buildings when they have further to span;)..thats essentially what your laminating for. to build up that level of material in either a verticle or horizontal plane to resist forces without making your main rails like 200mm wide either side
the whole point of the plate in the tank chassis and the bumper is to spread load so no one point takes all the energy. and if it does take a high point load there is always reinforcing
Post by streety6p on Aug 31, 2009 10:04:16 GMT 12
The exhaust runs through the top chassis rail, should make for a good boom box and add to the V8's appeal. Are you quite sure that you were not having your leg pulled? You can see the inlet port for the exhaust into the rail,, it is under the top rail by the first top hole next to the firewall end and yes they are for the exhausts you are not dreaming as i noticed them the other day when i had a look at it,, why no-one else has done this i have no idea
Post by leonardracing on Aug 31, 2009 11:59:00 GMT 12
It has been done before, in the very early days it was done often, I did it in 2001 in a Superstock bottom chassis rail, last I heard the practice has been banned. Saved about 40 kgs with no mufflers. They get really hot and that car used to burn my foot if the race stopped for to long, might be ok in the top rail tho.
Post by nogrip-31gm on Aug 31, 2009 12:04:52 GMT 12
wouldnt want that rail near my arm after a hard paced race...
cool idea though.. darn that chassis looks loooooong
Post by streety6p on Aug 31, 2009 12:15:15 GMT 12
wouldnt want that rail near my arm after a hard paced race... cool idea though.. d**n that chassis looks loooooong It does look long in the pic but its about the same as most other tanks in length,,Mind you it did look skinny from behind,, I may have to look at the bro,n,laws tank next time its bare to see if its skinny looking too,,I reckon your arms would get hot too with the exhausts in the top rail mind you keep ya warm on those real windy chilly nights
Post by nogrip-31gm on Aug 31, 2009 12:23:13 GMT 12
maybe its just my screen....
Post by chris13w on Aug 31, 2009 13:27:11 GMT 12
Are you quite sure that you were not having your leg pulled? You can see the inlet port for the exhaust into the rail,, it is under the top rail by the first top hole next to the firewall end and yes they are for the exhausts you are not dreaming as i noticed them the other day when i had a look at it,, why no-one else has done this i have no idea That still sounds horribly restricted.... And the headers then have to come out through one of those lightening holes to come up to that inlet you mentioned - why wouldn't you just put the inlet on the inside of the rail??? And the paint will burn - and it will be too hot on the top rail... And why does it still have the quarter round mounts off the front pillar that the exhaust covers usually mount to on Tanks? Still sounds like a leg pull! And its still ugly...
Post by nogrip-31gm on Aug 31, 2009 13:37:32 GMT 12
may be body mounts?or brackets for the cup holders?
Post by nogrip-31gm on Aug 31, 2009 13:40:44 GMT 12
oh,and in the 2nd pic on page 1 you can see the piping coming through the left side "port hole" for the exhaust..
Post by streety6p on Aug 31, 2009 15:07:00 GMT 12
You can see the inlet port for the exhaust into the rail,, it is under the top rail by the first top hole next to the firewall end and yes they are for the exhausts you are not dreaming as i noticed them the other day when i had a look at it,, why no-one else has done this i have no idea That still sounds horribly restricted.... And the headers then have to come out through one of those lightening holes to come up to that inlet you mentioned - why wouldn't you just put the inlet on the inside of the rail??? And the paint will burn - and it will be too hot on the top rail... And why does it still have the quarter round mounts off the front pillar that the exhaust covers usually mount to on Tanks? Still sounds like a leg pull! And its still ugly... Where the exhaust normally goes is for body mounting,Mind you ole peewee may run other things in that area or is it gunna be left open under the body to keep the top rail cool for the exhausts
Post by chris13w on Aug 31, 2009 15:47:48 GMT 12
oh,and in the 2nd pic on page 1 you can see the piping coming through the left side "port hole" for the exhaust.. True - and you can see on the picture of the left side that it does actually go up to the top rail on that side - must be a separate pipe on the right hand side though. OK - you're right, I'm wrong - it does go through the top rail! ....its still ugly though....
Post by stockkarmad on Aug 31, 2009 16:57:20 GMT 12
ugly hell no nothing sexier than tank go flat out or dealing to sum one and no have,nt got me beer goggles on
Post by dan77G on Aug 31, 2009 18:22:05 GMT 12
and no have,nt got me beer goggles on You sure???
Post by The Observer on Aug 31, 2009 19:31:52 GMT 12
You can see the inlet port for the exhaust into the rail,, it is under the top rail by the first top hole next to the firewall end and yes they are for the exhausts you are not dreaming as i noticed them the other day when i had a look at it,, why no-one else has done this i have no idea That still sounds horribly restricted.... And the headers then have to come out through one of those lightening holes to come up to that inlet you mentioned - why wouldn't you just put the inlet on the inside of the rail??? And the paint will burn - and it will be too hot on the top rail... And why does it still have the quarter round mounts off the front pillar that the exhaust covers usually mount to on Tanks? Still sounds like a leg pull! And its still ugly... It sounds like you would prefer a tank that looks like this Chris13w - which in fact is registered at your home track. Its got a ford y too, so that should keep you psyched too
Post by Wiseowl on Aug 31, 2009 19:35:55 GMT 12
oh,and in the 2nd pic on page 1 you can see the piping coming through the left side "port hole" for the exhaust.. True - and you can see on the picture of the left side that it does actually go up to the top rail on that side - must be a separate pipe on the right hand side though. OK - you're right, I'm wrong - it does go through the top rail! ....its still ugly though.... chris13W.. I just had to awaken from my winter sleep in the barn to reply to your concerns over the P R Tank's look...... !! Infact, my 1st post of the new-season At the end of the day.... you are... as usual toooooooooo technical...... Who gives a flying Ar.se about the looks...... Its built for battle...........So WATCH THIS SPACE !! Bring back the biff.. the drums......and watch your rear mirrors...!! Cheers An almost awakened for the spring.. WISEOWL
Post by ministock4d on Aug 31, 2009 19:52:41 GMT 12
i think hes having ya on with the pipes im sure there just for the look of the pipes coming out the back of the body he proberly goin to run them out under the side pod or sumthing
Post by BarryB on Aug 31, 2009 19:54:55 GMT 12
Infact, my 1st post of the new-season At the end of the day.... you are... as usual toooooooooo technical...... Ahaaaa!!! Got you on a technicality Wiseowl. As today is August 31st, it's technically the final day of the old season. You can't make your first new season post until tomorrow
Post by chris13w on Aug 31, 2009 21:25:19 GMT 12
That still sounds horribly restricted.... And the headers then have to come out through one of those lightening holes to come up to that inlet you mentioned - why wouldn't you just put the inlet on the inside of the rail??? And the paint will burn - and it will be too hot on the top rail... And why does it still have the quarter round mounts off the front pillar that the exhaust covers usually mount to on Tanks? Still sounds like a leg pull! And its still ugly... It sounds like you would prefer a tank that looks like this Chris13w - which in fact is registered at your home track. Its got a ford y too, so that should keep you psyched too Hey - that looks a bit more like a real car! Its still pretty compromised in the looks department though....
Post by chris13w on Aug 31, 2009 21:28:45 GMT 12
True - and you can see on the picture of the left side that it does actually go up to the top rail on that side - must be a separate pipe on the right hand side though. OK - you're right, I'm wrong - it does go through the top rail! ....its still ugly though.... chris13W.. I just had to awaken from my winter sleep in the barn to reply to your concerns over the P R Tank's look...... !! Infact, my 1st post of the new-season At the end of the day.... you are... as usual toooooooooo technical...... Who gives a flying Ar.se about the looks...... Its built for battle...........So WATCH THIS SPACE !! Bring back the biff.. the drums......and watch your rear mirrors...!! Cheers An almost awakened for the spring.. WISEOWL Happy spring awakening then Wise one!! You need to tell me all your secrets about Ministocks too - just bought one for the young fella - he can't race it till next year when he's 12 though...
Post by Regan O'Brien on Aug 31, 2009 22:45:14 GMT 12
how does a tank get on with the pipe sticking straight out the back when its meant to point down to the ground isint that the rule?
