Post by Speedway Central (David) on Nov 2, 2009 18:40:09 GMT 12
Is Transit NZ moving the Speedway in 5 years or so. I thought the bypass was going east of track not through it.
Post by batty73 on Nov 2, 2009 18:50:52 GMT 12
wow this is news to me whats happening....................
Post by Deleted on Nov 2, 2009 22:14:22 GMT 12
think this is one of those believe iit when you see it things ;D
Post by porry41 on Nov 2, 2009 22:20:43 GMT 12
its true will be lites out at old track & lites on at new track .costing transit about 5 mill .track will be on other side off top car park
Post by chris13w on Nov 2, 2009 22:32:42 GMT 12
Bypass from where to where - isn't it out way off the main road??
Post by BarryB on Nov 3, 2009 6:21:07 GMT 12
This has been going on for about a decade, with (I seem to recall) 3 options on the Huntly bypass. The entire motorway system from the Bombay Hills south has been delayed several times (remember the infamous taniwha?), and the track relocation has been previously mentioned in the NZDTR mag. I guess it will eventually happen, and 5 years does sound pretty plausible. With Transit's assistance, a great new track should be possible.
Post by porry41 on Nov 3, 2009 7:28:44 GMT 12
at the end of the express way just passed vincents old truck yard an interchange is going in .straight ahead in to huntly etc but motor way will turn left across country through the track an around the back of taupiri mountain through the back of rototuna to the cambrige rd intersection at tauwhare .tell u the rest in 5 years ;D but formation work has started at end off express way .well better get down there with my spade
Post by Rossco on Nov 3, 2009 9:06:24 GMT 12
Move it closer to Matamata, less traveling for us visitors . LOL . Cheers 77k
acorn
Post by acorn on Nov 3, 2009 9:11:38 GMT 12
Its already started to happen, if you look to the right as you go past the track you will see they have started to remove the large stand of trees over the other side of the mine pit and the mine is filling in the pit with its tailings. Been alot of work for our clients so far doing the proposed route ground investigations. Dave A
Post by mintie on Nov 3, 2009 11:49:44 GMT 12
Post by nzf2stocks. on Nov 4, 2009 21:52:23 GMT 12
So, do we get an offramp directly to the track? That would make it all worthwhile.
Post by stubbs5115 on Nov 5, 2009 9:46:01 GMT 12
i think its abit sad huntly moving, it's been there for so long and yet again hamilton/waikato speedway fans have to get used to another "home track", on the good side of the coin i guess huntlys new track will have nice fresh facilities etc
