jono
Post by jono on Jan 3, 2010 10:26:49 GMT 12
Has anyone got any results from the Springs lastnight? Sprintcars and Midgets?
ms89
Post by ms89 on Jan 3, 2010 10:37:59 GMT 12
sprint cars, brown, wilson,wako, midgets mosen,alach,swindell
Post by speedfreak12 on Jan 3, 2010 11:09:08 GMT 12
what about tqs? was nevano cowan racing 17a? how did he go?
Post by mgninc on Jan 3, 2010 13:39:09 GMT 12
Probably still some sorting out by SNZ after the 40 lapper
12 sprint cars in attendance, 21 Mark Browne won feature easily.
Midgets, some of the best and also oddest racing I have ever seen. Springs regulars in heats, and the test guys in 3 separate races, with the top 4 from each into a pole shuffle 2 lap sprint series.
Michael Kendall qualified 1st for the 40 lapper after the pole shuffer, Wayne Green on 2, Jerry Coons jr 3rd , Pickens 14th and Mosen somewhere down the grid also after the test series races.
Kendall led, only to flat and pull off, there were also a couple of spins and restarts back where they were placed prior to the incident.
soem great racing between Mosen, Pickens,Alach, Swindell and Coons Jnr, it got down tot the last lap and mosen and pickens came together resulting in pickens going over on his lid. Mosen then pulled off, then went to the back, then went back to the front??? and took the chequered flag. Mix of cheers and boos in the crowd.
17a nevano cowan won a heat in the TQs.
Kiwikids car rolled also, hopefully driver ok, same also with the older guy in 89a f2 midget.
Post by YankeeClipper10H on Jan 3, 2010 14:30:26 GMT 12
Huge crash with the F2 midget 89A. Got hit by another car whilst sliding into the corner at the end of the front straight. 89A flipped into the air completing TWO 360 degree barrel rolls in the air before landing on its wheels then bouncing up again for a third 360 barrel roll and finally stopping sitting on all fours. Whew!!
40 Lapper - 1st -13 Mosen, then 11 Alach, 1Aus (Swindell), 3USA, Coons............. 17K Brunt finished 5th or 6th resulting in 3rd overall for the International series so far.
Sprintcars -
Heat 1 1st - 9A, then 78A, 11A, 72A, 71A in 2:16.433
Heat 2 1st - 21A, then 71A, 56A, 27A, 96A, 59A, 9A, 78A, 35A, 11A, 72A with 4A DNF.
Feature - 1st - 21A then 56A, 27A, 78A, 71A, 35A, 11A, 96A, 4A, 72A with 9A and 59A both DNF.
Only scratching from the programme was 23A Adam Child.
Post by FantomFan on Jan 3, 2010 18:46:34 GMT 12
When did they start allowing video replays to impact decisions?
How many NZ titles could we get changed with video reviews?
rhino
Post by rhino on Jan 3, 2010 20:25:02 GMT 12
I think they call that up there the superstar clause, didnt look that much in it, should make for good chat heading over to the chili...
Post by fatrightrear on Jan 3, 2010 22:39:24 GMT 12
When did they start allowing video replays to impact decisions? How many NZ titles could we get changed with video reviews? If in doubt refer to rule book.still legal to run under protest"' replay only confirmed ,no grass cutting,
