Post by Chuckie on Jan 6, 2010 19:35:06 GMT 12
Qualifying results for the 50 lapper. Pickens, Kendal, Hatton, Mosen, Coons, Clarkson, Williams, hickman, Elliot, Insely, Buckley, Vincent, McCouchion, Allach, Swindell, Green. I know this is not complete field. That's just as far as the text went.
Seems track was slicking off. Pickens was last to qualify. And got fast time.
Semi main, Beale, Brunt, Kerr, Snooks.
B dash, Elliot, Insely, Buckley, McCouchion Beale, Green, Allach.
Post by Chuckie on Jan 6, 2010 19:50:19 GMT 12
A dash, Pickens, Kendall, Coons, Mosen, Hatton, Hickman. This will be top 6 grids for 50 lap feature.
Post by Streety 7g on Jan 6, 2010 19:57:55 GMT 12
any more results?
Post by Chuckie on Jan 6, 2010 20:09:10 GMT 12
Not yet. Will post as soon as I get them.
Post by Chuckie on Jan 6, 2010 20:44:50 GMT 12
Starting grids for 50 lapper. Pickens, Kendall. Coons, Mosan. Hatton, Williams. Hickamn, Clarkson. Insley, Elliot. Buckley, Mccutchion. Beale, Brunt. Green, Allach. Swindell, Vincent. Kerr, Smooks. Palmer, Gick.
Post by Chuckie on Jan 6, 2010 21:01:07 GMT 12
Results. Coons, Swindell (from grid 17), Kendal, Insley, Elliot, Allach, Hatton. More than 7 finished. Was only sent up to 7th in text. First caution lap 41. Pickens dnf, diff fail while leading mid race.
Post by speedfreak12 on Jan 6, 2010 21:12:42 GMT 12
jeez pickens doesnt seem to have much luck in these 50 lappers! what happened to mosen?
Post by YankeeClipper10H on Jan 6, 2010 23:07:02 GMT 12
Mosen's tyre went flat.
Post by m8sr8z on Jan 7, 2010 6:21:52 GMT 12
Results. Coons, Swindell (from grid 17), Kendal, Insley, Elliot, Allach, Hatton. More than 7 finished. Was only sent up to 7th in text. First caution lap 41. Pickens dnf, diff fail while leading mid race. Pickens was running 2nd, as he was until problems, Kendal got Pickens on the first green. Was a great race tho.
Post by johnf on Jan 7, 2010 6:55:20 GMT 12
kendall's best race for a while. A fine effort to out drag Pickens at the start and a good early lead only hampered by catching the tail of the field. An early yellow might have helped him.
Post by BarryB on Jan 7, 2010 7:18:40 GMT 12
Pickens led for 1 lap after passing Kendall, only to be passed by Coons the following lap after he had followed Pickens by Kendall in the slipstream.
Mosen clipped the wall coming off turn 4 approaching the white flag (in 4th place), but I'm not sure if that's what caused his flat right rear or whether it was the flat trye dragged him into the conrcrete.
The drive of the race for me was Swindell, from 17th to 2nd with a troublesome car with the benefit of only 1 caution.
Post by Speedway Central (David) on Jan 7, 2010 7:45:38 GMT 12
Was a great crowd
tank
Post by tank on Jan 7, 2010 9:21:01 GMT 12
i saw mosens right rear after race, no wonder it popped, there was nothing left of it. must of been running slicks ;D
Post by foxyken on Jan 7, 2010 9:41:01 GMT 12
Swindell running 1 car wide of the pole line from start of race payed off, seemed to be one of only few cars which could run that little bit wider. Really payed off in traffic. Fantastic drive from 17th. Although was never going to get Jerry Coons Jnr, was a fantastic race car, set up[ to run the bottom and did it so well. Bad Luck to Brad, fantastic drive by Kendell.
Post by mgninc on Jan 8, 2010 18:46:42 GMT 12
