Post by Admin on Sept 13, 2016 10:08:53 GMT 12
Post by Roger Ex 35A on Sept 13, 2016 19:32:32 GMT 12
Did I see Mike Pero Real Estate on the front splitter of the red mini, or should I go to Spec Savers.
Post by FantomFan on Sept 13, 2016 20:00:23 GMT 12
Post by Admin on Sept 13, 2016 21:34:25 GMT 12
Did I see Mike Pero Real Estate on the front splitter of the red mini, or should I go to Spec Savers. You did and you don't , also talk about the Hartleys and Kiwi 'can do' . That video has only been up a day and been viewed 136,000 times already.
Post by midway on Sept 13, 2016 22:44:13 GMT 12
Did I see Mike Pero Real Estate on the front splitter of the red mini, or should I go to Spec Savers. A vast improvement on your eyesight from the last encounter on poor visibility ,but have caution to the wind just in case you run into the back of a bus on the jaffa land motorway system ..
