Post by Phil15T on Dec 4, 2008 6:37:44 GMT 12
Well done Shane. Has finally put together a deal for Heavy Trax Hire NZ Super Saloon Champs. Good on ya mate we knew you would come through with something. Im concerned your centre of gravity might be too high. Thanks for all your help for NZ's Best Ever Super Saloon Title. Regards Phil 95T Promoter
Post by schumaaka on Dec 4, 2008 10:06:50 GMT 12
Not sure wether I will get it past the scruitineer, Probably over Height !!!!! Bugger
Post by Super Salooncar Fan on Dec 4, 2008 11:01:03 GMT 12
Its about time he came clean with his plans hes been hedging a lil .... mind you he will have to do a meeting b4 Which one is it the boat or the other if its the boat then we all have a problem Phil who is preparing the track .... man i hope it isnt shane as we may be getting a lil toooo much water Not sure wether I will get it past the scruitineer, Probably over Height !!!!! Bugger
Post by schumaaka on Dec 4, 2008 11:24:12 GMT 12
Its about time he came clean with his plans hes been hedging a lil .... mind you he will have to do a meeting b4 Which one is it the boat or the other if its the boat then we all have a problem Phil who is preparing the track .... man i hope it isnt shane as we may be getting a lil toooo much water Not sure wether I will get it past the scruitineer, Probably over Height !!!!! Bugger The Boats for next year at Huntly, Opps couldn't resist, Track preperation, Its a thanks less job.
Post by 351 on Dec 4, 2008 11:57:35 GMT 12
Whatdya mean Shane we all thank you eventually, when we can get a word in. See there is this continuous queue of thanks all the time. I personally use this time to thank you for most excellent track prep. Cheers Dave
Post by percy on Dec 4, 2008 12:10:28 GMT 12
Great to see an "A" on the side
Post by BarryB on Dec 4, 2008 13:37:38 GMT 12
Great to see an "A" on the side I noticed that too Percy............well done Shane.
Post by schumaaka on Dec 4, 2008 13:57:28 GMT 12
Post by greg on Dec 4, 2008 17:53:12 GMT 12
Im guessing thats the side panel from the 11A Kevin Moore car that Shane Maaka drove at the NZ Champs at Waikaraka in 2000.
Post by schumaaka on Dec 4, 2008 18:14:04 GMT 12
Im guessing thats the side panel from the 11A Kevin Moore car that Shane Maaka drove at the NZ Champs at Waikaraka in 2000. Good spotting, was on the car for the 1 australia driver that drove it after me.
Post by HRC on Dec 4, 2008 23:49:57 GMT 12
well shane most of us start building a car from the bottom up but i suppose a right side door is a good start anyway i better get some sleep off to the north island sprint car champs tommorow night so i better get home (as just finnished putting the motor back in pulled the dam thing down as lost oil pressure you know pulled the crank out etc only to find after all that that the oil pump bypass was stuck open all was good inside tho yawn
Post by schumaaka on Dec 5, 2008 7:25:56 GMT 12
well shane most of us start building a car from the bottom up but i suppose a right side door is a good start anyway i better get some sleep off to the north island sprint car champs tommorow night so i better get home (as just finnished putting the motor back in pulled the dam thing down as lost oil pressure you know pulled the crank out etc only to find after all that that the oil pump bypass was stuck open all was good inside tho yawn You know what they say? the problem will always be in the last place you look!!!, Good luck at the North Islands. See you in January
