mags
Post by mags on Dec 24, 2008 7:51:11 GMT 12
r you are aloud to move the gear stick to the side of the car so it not in the middle between your legs.
Post by tank11 on Dec 24, 2008 9:04:43 GMT 12
Ask SNZ. Good idea, so answer will be no........... ;D
RevXS
Post by RevXS on Dec 24, 2008 10:03:56 GMT 12
Cut it down shorter,when mines in 2nd the gearstick ends up pretty much tucked out of the way
mags
Post by mags on Dec 24, 2008 10:37:54 GMT 12
i thought u cant because they didnt come out like that, they only came out straight up and down
Post by tank11 on Dec 24, 2008 11:21:51 GMT 12
One of ours is bent, because it hits the seat in 2nd otherwise.
Young driver, seat right forward. ;D ;D
Post by nogrip-31gm on Jan 4, 2009 6:34:35 GMT 12
mines bent...it goes up-over-up again..a big S...
Post by cap209 (porterracing) on Jan 4, 2009 8:28:45 GMT 12
Posted by nogrip-31gm on Today at 6:34am mines bent...it goes up-over-up again..a big S... I thought you had a stock car not a ministock. Just cut it down there is no rule to say you can't modify the gear shifter
Post by mintie on Jan 4, 2009 11:07:02 GMT 12
just be careful with cutting as there is no rule to say you can, even though there is nothing to say you can't. check first
shawry
oneday i will fix my streety. one day
Post by shawry on Jan 4, 2009 11:18:34 GMT 12
My mate had a balljoint beside his seat and i cant remember how but somewhere it had a bit of 25x25 box section coming from the gear box to it not sure how it was connected though, if im correct i think it was a bit off a mission to change gears between 1st and 2nd but that could of been gearbox going out because it did blow after the first practice.
shawry
RevXS
Post by RevXS on Jan 4, 2009 14:56:39 GMT 12
Wouldnt matter if you either cut or bend,Both ways it not standard so would they rather us cut some bits out of the seat so the gearstick doesnt hit the seat if they wanted to be real picky on it haha
Post by mcarthur71g on Jan 21, 2009 22:52:34 GMT 12
what's the big deal? there's really no point in changing it! - you really only do one gear change throughout the whole race, the one at the start (give or take for restarts...), other than that it's pretty much outta they way!...?
mrx46
Post by mrx46 on Jan 30, 2009 17:08:21 GMT 12
what's the big deal? there's really no point in changing it! - you really only do one gear change throughout the whole race, the one at the start (give or take for restarts...), other than that it's pretty much outta they way!...? It's not going to make any big difference is it ? Theres no point in changing it. If it hits the seat just take it out and bend it forward.
