Post by 98wsaloon on Jul 13, 2010 18:02:39 GMT 12
looking good , be good to have you there.. can see only one mistake..ya should have coppied a front end of a car that actually goes around corners ;D ;D ;D ;D ;D ;D ;D ;D...sorry chris
Post by scotty 911w on Jul 18, 2010 16:06:22 GMT 12
looking good , be good to have you there.. can see only one mistake..ya should have coppied a front end of a car that actually goes around corners ;D ;D ;D ;D ;D ;D ;D ;D...sorry chris lol,but i dont think it was chris driving when it went into the wall
Post by scotty 911w on Jul 18, 2010 16:19:58 GMT 12
well i found a rack $100 on trademe and started mounting it,then ran out of mig gas ,so i moved onto something else. i got some old shifter cables out of a mitsi van and made up the shifter for my falcon 3 speed.i was thinkin of mounting the shifter on the lhs in the cockpit as there is plenty of room over there.can stick it any where due to the lenght of the cables,if i want.i had no idea how it was all gonna work ,just pulled the top of the box figured out what does what and went from there.seems to work pretty well. ;D my new rack, the gearbox lever ends are just temp at the mo
mcmoo
Post by mcmoo on Aug 6, 2010 21:44:05 GMT 12
Hey Scotty, good to see the progress. Had not seen this post before now. Well done, Good luck with the budget for this season. See ya at the track. McMoo
Post by scotty 911w on Aug 21, 2010 16:19:35 GMT 12
well not much to report ,but im having an alloy tank made for me and been muckin about with the steering, oh thats right ive secured a very good deal from GASKIN FORD for an au 4.0l motor will be taking delivery of that soon so then ill be into it, engine geabox mounts,finalising steering coloumn,fitting fuel ines brake lines ,coolant pipes etc, i awoke this morn to some self induced madness ;)ive decide to call my car..................MY LITTLE PONY ;D ;Dyep thats rite will be pink n all for those of you who dont get it, because its a mustang but not quite a thorobred(running a 6 not an 8) ,hence the little pony ill post some pics of my tank when its done, scotty
Post by glen26 2ks on Aug 23, 2010 14:45:30 GMT 12
lol good one scotty
Post by scotty 911w on Sept 26, 2010 20:17:27 GMT 12
picked up my motor yesterday,should be a goodn,only done 88 thousand kms ;)so heres what i did today(which is why i wasnt at the workin bee) engine mounts engine in,woo hoo plenty of room for a massive turbo ;D had to cut a chassis rail to get the engine low enough not a bad fit considering i built the front end without an engine ;D some other stuff ive been up to latley throwing some paint around new dash double shear mount birdcages, now the fun begins bell housing/clutch combonations ecu and related stuff not too looking forward to that. make up extractors/headers exhaust system and them plumbing.
Post by scotty 911w on Oct 3, 2010 15:55:47 GMT 12
well did my ususal,decided i didnt like what i had done ,so.........off it comes engine mounts version 2.0 top bar is bent to clear oil filter started on some wiring yesterday,boy thats fun.................not might also have a problem with the rack i brought,i dont think its long enough........doh
Post by scotty 911w on Oct 16, 2010 11:03:37 GMT 12
ok ,a few nights in the shed and this is what ive accomplised.it might not look like much,but when you make things 5 times it can take a little longer steering rack in just made a rack extension made pedal box not quite finished but you get the idea
Post by chris13w on Oct 16, 2010 11:11:17 GMT 12
Hey Scott - Nice work on the pedal box! Just wondering if that rack is too long now though?? If the tie rods are in line with the bottom arm (hard to tell from the picture angle) then it needs to be the same length as the spacing between the bottom arm pivots to get zero bump steer. All looks good though - I must come round for a look sometime!
Post by scotty 911w on Oct 16, 2010 15:00:19 GMT 12
Hey Scott - Nice work on the pedal box! Just wondering if that rack is too long now though?? If the tie rods are in line with the bottom arm (hard to tell from the picture angle) then it needs to be the same length as the spacing between the bottom arm pivots to get zero bump steer. All looks good though - I must come round for a look sometime! according to your books the steering rack ends need to be inline with top AND bottom mounts to get zero bump steer,mabey i read it wrong,
Post by scotty 911w on Oct 16, 2010 15:06:14 GMT 12
Post by chris13w on Oct 16, 2010 18:32:36 GMT 12
Totally correct! That's why I said I couldn't tell from the picture if it was in the same plane as the bottom arm, so if its up higher - absolutley right! That "My Little Pony" is going to be awesome when its finished!
Post by scotty 911w on Oct 19, 2010 17:50:03 GMT 12
well what a busy sunday and monday night,if you liked the pedal box chris you should love this ill make an alloy pedal when i come across some pedal box and steering column fitted,ten points if anyone can tell what the column came out of ;D now you see me now you dont ;D now i can start running brake lines.
Post by 4zfed on Oct 21, 2010 7:10:48 GMT 12
Keep up the good work Scotty & the updates. It will all be worth the long hours your putting in
Post by callum33 on Oct 21, 2010 19:46:40 GMT 12
i bet the steering column came out of a car! probably manufactured sometime in the last 100 years - now what do i win?
muff 21w
HEYBURN built T MACS
Post by muff 21w on Oct 21, 2010 23:58:37 GMT 12
hillman avenger?
Post by tank11 on Oct 22, 2010 7:33:57 GMT 12
i bet the steering column came out of a car! probably manufactured sometime in the last 100 years - now what do i win? ten points, he said.
Post by nogrip-31gm on Oct 22, 2010 8:14:21 GMT 12
wll its a tilt column so jap spec.. corolla??
Post by Brett85p on Oct 22, 2010 9:43:41 GMT 12
Nice work Scotty!
Have you thought about making the cover over the pedal box hinged or zeus clipped on so you can remove it quickly to access the master cylinder?
One other suggestion, putting a foot rest flush between the brake and clutch, it gives you somewhere to put your left foot when you are not on the brake and then you can just slide your foot across to the brake when you need to.
Good luck!
