Post by Wingnut99 on Jan 21, 2009 6:48:46 GMT 12
Post by nogrip-31gm on Jan 21, 2009 6:55:19 GMT 12
wow if you look to the side of the screen it looks as if it speeds up
Post by Regan O'Brien on Jan 21, 2009 7:03:56 GMT 12
couldnt check mine steering box arm goes above tapit cover got them wondering what other problems they going to meet
Post by 41ford on Jan 21, 2009 8:51:31 GMT 12
wow if you look to the side of the screen it looks as if it speeds up Your Right There!!! It does seem to speed up. Had to do it a couple of times to make sure I wasn't getting sucked in lol
Post by Wingnut99 on Jan 21, 2009 13:48:07 GMT 12
Post by Teams Junkie on Jan 21, 2009 14:50:01 GMT 12
Don't put all engine builders under a cloud here Wingnut. Tell the whole story or leave it alone
Post by The Observer on Jan 21, 2009 15:25:47 GMT 12
Post by The Godfather on Jan 21, 2009 15:28:22 GMT 12
I'll head back to the dunces corner, as I have no idea what the heck this thread is about ?? ??
Post by Markus M on Jan 21, 2009 15:31:54 GMT 12
I'll head back to the dunces corner, as I have no idea what the heck this thread is about ?? ?? You and me both Godfather Mind you look at wingnuts avatar pic may be needs to take his own advice ;D ;D ;D ;D ;D ;D Cheers
Post by Deleted on Jan 21, 2009 15:36:21 GMT 12
This weekend could be interesting, I guess we'll all know for sure afterwards. Until then it's just speculation and rumors ;D
Post by MadMarty13B on Jan 21, 2009 16:16:08 GMT 12
another rule interpretation change no doubt
45r
Post by 45r on Jan 21, 2009 16:45:54 GMT 12
Speculation (no)
It is a known fact there are motors out there with cam lift of 560 and more.
Wingnut is onto something, SNZ need to grow some nuts and start checking engines.
Post by Deleted on Jan 21, 2009 17:04:56 GMT 12
SNZ need to grow some nuts and start checking engines. Feel free to protest those is question, as per Rule G10-3 If it what you say is a fact, then the protester gets their $300 refunded that it costs to protest an engine.
45r
Post by 45r on Jan 21, 2009 17:25:06 GMT 12
It is more the fact that SNZ know this is going on but chose to turn a blind eye !!!!!!!!!!! A lot of drivers don't have a clue what there cam lift is and if there engine builder has got it wrong and they are checked it is on them, (as we have seen in the past). The engine builder walks away sot free is this rite? ?
Post by DTM1 on Jan 21, 2009 17:28:27 GMT 12
It is a known fact there are motors out there with cam lift of 560 and more. On what "known facts" could you possibly base your statement on?. Unless the owner of a motor with excessive lift has been mouthing off,the only other way such a motor would be "known" about,would be via an inspection......and apparently,nuts need to be grown before that happens.
Post by craigsvo on Jan 21, 2009 17:40:14 GMT 12
i have a hartley holden v6 and would be happy to get it inspected one of our other engines have been done on many times and was totally fine.
dont know who this thread is pointed at but just saying hartleys are fine
Post by Teams Junkie on Jan 21, 2009 17:57:41 GMT 12
Was it measured with a solid lifter in place or a hydraulic lifter?
Post by craigsvo on Jan 21, 2009 18:05:12 GMT 12
not sure we had to take off the rocker cover and then they bolted on some thing and had to then rock the car back and foward was fine there were about 3 of the same motors there.
Post by Stevo on Jan 21, 2009 19:48:11 GMT 12
If someone has some suspicions about someone elses motor, put ya money where ya mouth is and get it checked properly, instead of starting some vague thread throwing speculation and generalisations about. If you "know" someone is cheating do something about it.
hermo
Post by hermo on Jan 21, 2009 21:33:04 GMT 12
Was it measured with a solid lifter in place or a hydraulic lifter? If it runs a solid lifter then it would be checked like that wouldn't it? I dont think that SNZ is allowed to change your engine before they check it are they? I feel that the person who is making the insinuations should come clean and say what he thinks the problem is or just shut up. You are casting doubt on all cars and engine builders without putting up the proof of any wrongdoing.
