Post by Morpheous on Jan 30, 2009 19:29:54 GMT 12
Any results or happenings from Stratford tonight??
Post by thunderbird1 on Jan 30, 2009 19:51:42 GMT 12
I hope so. Read that some were taking their laptops so we hope and wait. Anyone know what the weather is like tonight and for tomorrow at Stratford.
Post by speedfreak12 on Jan 30, 2009 21:59:35 GMT 12
how bad was scottys roll? if he still qualifies will he be sweet for tomorrow night?
Post by drew on Jan 30, 2009 22:03:31 GMT 12
Scotty lane put it on its roof all by himself avoiding 55s after ward spun out... Only buggered the wing.
5w (I think using 15w tonight?) rolled after hitting the wall and the 36a slammed into him getting some air. 36a ok..
Bunta got HUGE air at the start of his heat after going up and over the back wheel of a car in front, deflating his rear inside tyre, and ended up retiring from the race.
Something broke in the 1nz and he retired from a race, but was back again in the next..
as for qualifiers.. dunno LOL. I only know that 7 Naki drivers are through.
Get some pics up soon-ish...
Drew
Post by Aaron Drever on Jan 30, 2009 22:13:43 GMT 12
Crowd not too bad.....
Everyone qualified basically...... except 1nz will be doing repercharge.
Standouts were as follows: Jamie Fox, Brian Jesson, Mark Dixon and John Jackson.
Scotty Lane did qualify 8th = and the top 9 from each group went in.
Thanks to Barry Brown for the update
Post by Wildcat on Jan 30, 2009 22:15:40 GMT 12
Did B MCPHEE make it 5w /15w see he rolled earlier
Post by worldno1 on Jan 30, 2009 22:51:21 GMT 12
Did B MCPHEE make it 5w /15w see he rolled earlier na mate damage front end pretty massive, should be out in repo tomo tho
Post by Saloon29s on Jan 30, 2009 23:05:55 GMT 12
Give me about 20 minutes and the qualifiers will be up on www.startford-speedway.co.nzJust got back from the clubrooms after celebrating the 829s Stockcar finally finishing three races in a night.
Post by HIGHWAY45 on Jan 30, 2009 23:06:36 GMT 12
QUALIFIERS no particular order although 2nz was top qualiifer followed by 4s and then 84c i think is the correct top 3 qualifiers on points
BLUE GROUP
4s, 6a, 11a (running as 211a), 21a, 29e, 41a, 67s, 67c (running as 17c) 121s
Top qulaifer was 4s. 67s had a dnf but backed up with a win and then good 3rd heat where made some passes. 21a passed chequered flag in heat 3 in a not so good looking cloud of smoke. 29e through it around, tryed the wide line here and there. 211a looked to be cruising and just content on qualifying as did 4s. 67c made it through but looked to struggle with the pace
RED GROUP
2nz, 3nz, 6gm (running as 16gm), 10s, 11s, 18r, 19a, 55s, 84c
2nz top qualifier from both groups. very patient and controlled driving and content to qualify. 3nz had good win from front grid in heat 1 and then looked steady. 16gm pushed all night and although looked bit loose here n there qualified easily. 10s had a dnf but 2nd and 3rd heat points helped him in. 11s good when track clear ahead of him.18r consistent and has improved heaps.19a scotty lane flipped it while trying to see what track had to offer out wide in 3rd heat (his words). 84c made it clean sweep for sth island entrants to qualify 4/4 pretty good going.
repercharge should see 36a and maybe 12s or 5 s off front.
1nz, 97h or 5w will be off back as dnf in first heat and then werent seen again. only half dozen or so cars in repercharge and top 2 to go through. 1nz could do it as when was going looked quick and aggressive
track breakdown s - 7 a - 6 r - 1 c - 2 gm - 1 e - 1
Post by 41ford on Jan 30, 2009 23:07:09 GMT 12
Sorry guys I didn't end up taking laptop down as it was too dusty!!!
1nz Tama broke a rocker in the engine, so thanks to some of the naki boys some spare's are around and he will be back for the rep 2moro night.
Foxy was improving and Dixon looking (my money's on him)
These two prob the quickest cars out there. Hope they get good grid draws both through on 31 points
Post by BarryB on Jan 30, 2009 23:14:10 GMT 12
Something broke in the 1nz and he retired from a race, but was back again in the next.. 1nz failed to front for the rest of the night, but should be on grid 6 tomorrow, and hopefully can make it through to second within the 15 laps. Garry Parker (21a) had no idea on the problem whhen I left, huge plumes of smoke but had oil pressure etc. Had lost all his coolant however.......
Post by Saloon29s on Jan 30, 2009 23:29:42 GMT 12
Post by 41ford on Jan 30, 2009 23:36:37 GMT 12
you're a champ thanks for that
Post by Glenn, Ex 269s on Jan 31, 2009 7:18:31 GMT 12
got a bit of footage last night using the racecam (from the stands), but forgot to set the sound up (had it set to run from in the car)and the sound is rubbish so isnt worth posting up, I set it up correctly just a few moments ago, so will try and capture the 3 finals tonight and post up, be great if i could get it set up in a car tho. ;D ;D ;D, actually sod the racecam, just found that you can upload up to a Gb onto youtube now (yea its been a while since i put anything up) so i'll try capture the heats on handycam
Post by drew on Jan 31, 2009 7:57:38 GMT 12
Cant show you too much of the good oil yet, but here are a few teasers from last night.. Drew Man from wellington's night ended here. Man from Huntly's ended here. Scotty doing what he does best.. Then had a blond moment.. Jacko spining in the first heat. POP! Ward getting it wrong and going backwards during a spin.. Might get some more up later... Drew
Post by Glenn, Ex 269s on Jan 31, 2009 8:14:10 GMT 12
darn shouldnt have deleted the footage i took as it shows clearly jacko getting a belt up the toota from the 19 car causing the spin
Post by Markus M on Jan 31, 2009 8:15:57 GMT 12
Awesome pics drew Pretty nasty looking rollover for Mr Mcphee hope he is ok. Cheers
Post by mattrix on Jan 31, 2009 8:38:02 GMT 12
talked to brians mcfee's crew this morning brians fine cars bit bend but thay think thay will make it out for tonight, Tama broke a rocker in engine so should be right for tonight also
Post by youngone on Jan 31, 2009 10:15:27 GMT 12
Good racing, not sure about why they let a guy who has spun they drive closer to the track and "stall" forcing the orange lights to come on. That is what part of the cause of the last roll over was all about.
One other comment, Rodger the commentator. Can you please talk about some other cars than just Merv Julian or Jacko. All we heard in the first race was how good Merv was, that he was driving out of the 2nd corner etc etc. Then when he came out for the second of his heats I said to my mate "how long Merv is mentioned again" and blow me down as soon as he came out it started up again. Sure he might be a good driver but how about some history and details of the other drivers out there?
Interesting the first stock car race got under way before the flag man had dropped the green flag!!! They put the green lights on anyway.
Post by Devilracer on Jan 31, 2009 12:32:30 GMT 12
I had been txting results to cabby1 not sure if he was going to post on here tho. If someone wants me to txt them to post tonight, txt me on 0272281434.
Matt.
